repetitive disconnecting of a wireless client - Deauth_ind reason: Unspecified reason (1)
Any news on this? I have seeing it all the time with a AX86S on the latest firmware - and before updating I did a factory reset of the router. I am running an AiMesh setup this time. I only looked at my logs because my wife's work PC disconnected in the middle of a meeting today. There is only 1 occurrence with per PC, but something else is doing just about ever second! Going to work on determining which device that is...
You are replying to an old discussion from 2.5 years ago.
I suggest you collect more trouble observations there and begin a new discussion here to consider your trouble, if any. One dropped work meeting session is not much to go on... could happen to anyone.
OE
I tracked the offender down to a La Crosse weather station. I removed its power and my logs look better. I do see some other things doing the same type of things from time to time, but I think I am able to explain most away (and assume the remaining ones are iOS devices set to Private).
