[Request] Anyway to reboot AiMesh nodes from the main router interface?
Eric Lieb
I can't find a way to reboot the AiMesh nodes from the main router's interface. Right now I have to use the Asus software on my phone to reboot a node, or physically go to the node and power cycle it. Is there anyway to add the ability to reboot a node, or am I missing it?
You can ssh into the node and reboot from the command line. You can also install scmerlin using amtm and that will give you a handy menu to restart various services as well as rebooting the node.
AiMesh is closed source, and outside of my control.
