I'm using an ASUS router with Merlin firmware and a PPPoE WAN connection. All LAN clients successfully obtain global IPv6 addresses via DHCPv6-PD and have full IPv6 internet access. However, the router itself cannot reach any IPv6 destinations - pings and traceroutes from the router fail beyond the second hop. I've suspicion that this is caused by my ISP, but I wanted to see if anyone faced something similar and found a workaround. My ISP provide IPv6 but no technical details are published, nor they will provide support for using my own router (they provide specific brand only which is completely locked)
The below trace route from router SSH, google domain was reoslved, the hop 1 & 2 seems to belong to my ISP as the prefix is different than the one assigned to me. I tried with `traceroute6 -n -i ppp0 ipv6.google.com` as well with the same result
I tried to find the default route and the interface with the help of LLM
- Global IPv6 prefix is shown in the router Web UI
- All clients can connect and ping IPv6 hosts
- Router cannot ping IPv6 targets
- Using the Web UI -> Networks tool (Only IPv4 targets works)
- Ping from SSH is timing out
- DNS can resolve IPv6
- Router cannot connect to IPv6-only VPN (router as VPN client)
- IPv4 VPN connect successfully
- Connection type: Native
- Interface: PPP
- DHCP-PD: Enable
- Accept Default Route: Enable
- [IPv6 WAN Setting]
- WAN Prefix Length: 56 (was auto configured once connected to ISP)
- [IPv6 LAN Setting]
- LAN IPv6 Address: 2001:ffff:4321:5678::1 (was auto configured once connected to ISP)
- LAN Prefix Length: 64 (was auto configured once connected to ISP)
- LAN IPv6 Prefix: 2001:ffff:4321:5678:: (was auto configured once connected to ISP)
- Auto Configuration Setting: Stateless
- [IPv6 DNS Settings]
- Connect to DNS Server automatically: Enable
- [Auto Configuration Setting]
- Enable Router Advertisement: Enable
# traceroute -6 google.com
traceroute to google.com (2a00:1450:4019:800::200e), 30 hops max, 16 byte packets
1 2001:ffff:100:10:: (2001:ffff:100:10::) 2.816 ms 2.442 ms 2.808 ms # <-- This what seems to be the ISP gateway
2 2001:ffff:1f06:aa::b (2001:ffff:1f06:aa::b) 3.279 ms 3.160 ms 2.942 ms
3 * * *
30 * * *
# ip -6 route show
2001:ffff:100:10::45d5 dev ppp0 proto kernel metric 256 pref medium # <-- This what seems to be the ISP gateway
2001:ffff:4321:5678::/64 dev br0 proto kernel metric 256 pref medium # <-- This the the global IPv6 prefix assigned to the router
default via fe80::200:5eff:fe00:101 dev ppp0 proto ra metric 1024 expires 1331sec pref medium
# ip -6 addr
1: lo: <LOOPBACK,MULTICAST,UP,LOWER_UP> mtu 65536
inet6 ::1/128 scope host
valid_lft forever preferred_lft forever
68: br0: <BROADCAST,MULTICAST,ALLMULTI,UP,LOWER_UP> mtu 1500
inet6 2001:ffff:4321:5678::1/64 scope global # <-- This the the global IPv6 prefix assigned to the router
inet6 fe80::7e10:c9ff:fe58:e0a8/64 scope link
69: ppp0: <POINTOPOINT,MULTICAST,UP,LOWER_UP> mtu 1492 qlen 3
inet6 2001:ffff:100:10::45d5/128 scope global # <-- This what seems to be the ISP gateway
inet6 fe80::f174:761b:cea8:ce2/10 scope link
# ifconfig
br0 Link encap:Ethernet HWaddr e3:80:dd:11:a7:f3
inet addr:192.168.50.1 Bcast:192.168.50.255 Mask:255.255.255.0
inet6 addr: 2001:ffff:4321:5678::1/64 Scope:Global # <-- This the the global IPv6 prefix assigned to the router
inet6 addr: fe80::7e10:c9ff:fe58:e0a8/64 Scope:Link
UP BROADCAST RUNNING ALLMULTI MULTICAST MTU:1500 Metric:1
RX packets:738811 errors:0 dropped:59 overruns:0 frame:0
TX packets:1502179 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:103088636 (98.3 MiB) TX bytes:1247449496 (1.1 GiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MULTICAST MTU:65536 Metric:1
RX packets:37248736 errors:0 dropped:0 overruns:0 frame:0
TX packets:37248736 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:8367122514 (7.7 GiB) TX bytes:8367122514 (7.7 GiB)
lo:0 Link encap:Local Loopback
inet addr:127.0.1.1 Mask:255.0.0.0
ppp0 Link encap:Point-to-Point Protocol
inet addr:12.34.56.78 P-t-P:12.34.56.1 Mask:255.255.255.255 # My actual public IPv4 was here and the P-t-P looks to be my ISP gateway
inet6 addr: fe80::f174:761b:cea8:ce2/10 Scope:Link
inet6 addr: 2001:ffff:100:10::45d5/128 Scope:Global # <-- This what seems to be the ISP gateway and not the prefix assigned to me
UP POINTOPOINT RUNNING MULTICAST MTU:1492 Metric:1
RX packets:1468981 errors:0 dropped:0 overruns:0 frame:0
TX packets:690727 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:1209230527 (1.1 GiB) TX bytes:90669250 (86.4 MiB)
