Just search for 8dBi omnidirectional antenna. You'll find they are quite large. Don't expect miracles, especially if you are trying to improve 5 GHz range.Is it possible to swap out the antennas that come with this router for bigger/better ones that would influence better wireless signal at all? And if so what antennas would we be looking at is there a name/brand at all?
Depends on what you mean by "better". As I said, they won't work miracles to improve coverage.Thanks - are these better than the stock ones and if so why? I'm just trying to learn about antennas and if there are ways to improve on the stock ones.
My question was 'Is it possible?' - it's just a theoretical question. I don't intend to start building 3D models etc just for an answer to that.
Is it possible? What antennas would actually be better than the stock ones?
Thread starter | Title | Forum | Replies | Date |
M | Ac68U broken antennas. Can it be fixed, or is aliexpress or ebay ok? | ASUS AC Routers & Adapters (Wi-Fi 5) | 7 | |
O | Got used RT-AC68U E1 and tried some mikrotik antennas | ASUS AC Routers & Adapters (Wi-Fi 5) | 7 |
Welcome To SNBForums
