I'm trying to set the timezone on a RT-AC3200 without success. From the Administration/System tab, it is defaulted to U.S. Central Time. I select my timezone from the dropdown menu and hit Apply; the screen bounces back up to the Router Login Name field. I type in the login name, hit Apply again and then get an error message box: "Specified time interval can not overlap."
There doesn't seem a way to manually set the time. Any ideas on setting the timezone on a AC3200?
Thank you.
Thank you.
