Hi Guys, Just joined. Hoping I can get some help.
Today my RT-AC5300 randomly went back to factory defaults. It happened a few years ago, never thought anything of it at the time.
So today, after it happened again, set it up again as per last time, but upon power cycle, it did not boot, and entered rescue mode.
Did the NVRAM reset - but stayed in rescue mode. Confirmed rescue mode with ping to 192.168.1.1 and TTL=100
Tried upgrading firmware (which was already the latest) using the PC recovery tool, firmware upgrade failed at about 85%, but router booted up
Basically I am now stuck with a router that seems to work normally, unless you hit the reboot option on the web interface, or reboot in Telnet, or power cycle, where it goes back into recovery mode. Making and saving a config change seems to work fine. I then need to attempt a new recovery firmware tool session to get it to boot up, but firmware uploading is never successful. It like there is a problem with the bootloader that is bypassed with the firmware tool.
Of course, its 3 months out of warranty, and with Covid I am not finding any luck to buy a new one...
Syslog attached in case it helps.
