Rt-ac56u 5ghz channels missing
Pierino
I hate to ask this because it seems like I should know but I just bough an rt-ac56u.
It had cfe 1.0.1.9, I upgraded the cfe to 1.0.2.9 hoping it would improve the 2.4ghz problem. It didn't but now I notice that my 5ghz channel selection stops at 140.
My rt-ac68u goes up to 161.
I'm in the US and the cfe I flashed was labeled US.
Why don't I have the choice to select 161 for the rt-ac56u?
I posted in this subforum because Ive tried Johns latest fork and RMerlin 380.59
Btw, is there any way to make the 2.4ghz better?
Are you 100% sure you flashed with a US version, and also that the CFE was intended for the RT-AC56U?
Check those commands:
nvram get 0:ccode
nvram get 1:ccode
Nvram get 0:ccode returns a o.
Nvram get 1:ccode returns ALL
Thats why, thats a compiled CFE from source, so region is not set, you need to change it.
I will update the file to US region before you kill the router. :-)
Thanks. I still will have to reflag the cfe. Wouldn't it just be easier to make the change in the cfe that I have already changed my macs and wps pin to?
My backed up cfe says 0:ccode=US
1:ccode=US.
Can I change the new cfe to those values and reflash it?
You can, but pay attention that you are not replacing only but increasing / decreasing it on the bootloader, if not done properly will result in a dead router.
I only can update the file later today.
I think I'll just flash my old cfe back to it.
Doesn't seem like there is any benefit to the 1.0.2.9
I know you said that. I thought that since I flashed back the old cfe that you might decide not to do it.
I'm not an idiot. Lol. I can read. I didn't say you might want to do it now.
I don't see why I wouldn't do it based on your decision. Who told you were?
I don't see the word idiot in there, the idea was to tell you once again that I would do it later today after your reply and I will.
It's not part of me offending people, even more for free...
Ok, I'm sorry. Lol. It just seemed like a parent telling a kid "I says I will do it later."
By the way do you offend people for money?
