RT-AC66R Drops Connection
bitzerjdb
I'm having an issue with one of my APs. My laptop (Windows 10) will drop the network connection and then not see any Wireless Networks. This only happens when connected to 5gh..2.4 stays solid. I reset the router and it works fine for a few hours, then it starts dropping.
If I turn off that AP, I connect to the backup and it works fine....no drops.
I have the latest version of Merlin Firmware installed.
I think the AP has an HW issue and when it is heating up, it is causing the issue.
Thoughts?
Fixed.....bad Network card in the Laptop. Seems that when connected at a higher speed would cause the issues. When connected to the secondary AP (farther away), the issue did not show up. Glad the replacement AC7620 cards are super cheap!
