PlayaSucia
I'm getting issues with a new RT-AC66U B1 dropping internet. It isn't disconnecting from the router just the internet connection is dropped, then after about 10 seconds give or take it comes back on.
I did go though the 'Troubleshooting wifi issues' sticky at the top of this forum and I have updated the firmware (the one dated 9/19/18), did a factory reset, deleted profiles on the client, ect..
I'm using the basic default settings aside from passwords, SSID and ...
-changed 2.4ghz channel from auto to 11, (an unused channel according to inssider)
-changed 2.4ghz from 20/40 to 20
-changed 5ghz channel from auto to 48 (I tried higher band too but no difference)
-set IPV6 to native (I use comcast and online IPV6 tests check out)
-turned off UPnP
-there is nothing enabled (no AIprotect, AIcloud, QoS, external drives)
When I'm streaming or whatever the status shows the memory usage under 30%, the cpu typically around 5% with small spikes up from time to time. Nothing out of the ordinary.
Background – I had been using a older Netgear WNDR3700v2 (N600) router for around the last six months and it worked fine until the 2.4 radio burned out. Since I have several 2.4 clients I replaced it with this RT-AC66U B1 in part because it seems to be one of the more popular models around here in the sub $100 range.
Overall get better signal around the house with the RT-AC66U B1 but the speeds slightly lower than the N600. I'm pretty realistic about wifi speeds and didn't expect a big change despite going from a 600 to 1750 router, however I did expect it to be relatively the same or slightly better.
I'm going to give it a week but if it keep dropping I'll have to return it and try something else. Is this uncommon? Are there any setting I should look at?
Thanks.
-turned off UPnP
Thanks.
