I agree but is it good for anything else or should I throw it away?
Yes, If you require switch ports in your network (equivalent to a switch) you could use the device for that. Run a cable from your good router, to this device) Just remember to turn off DHCP etc.. Use it as a layer two switch..I had already opened it. Nothing loose or disconnected.
Use it as as a switch ports, router mode or not?
You mean like adding ports to my existing router or something?
I had a client reporting the same on a Linksys WRT54G and the connector soldering was broken inside, i have solder it again and it works like new.![]()
Sure but that decision was not mine, the client is the boss.
Btw, that happened maybe 4-5 years ago, no RT-N10 existed at that time LOL![]()
Thread starter | Title | Forum | Replies | Date |
N | Recommendation For Next Router. Currently have RT-AC88U and RT-AC68U (as a node). | ASUS AC Routers & Adapters (Wi-Fi 5) | 7 |
Welcome To SNBForums
