RT-AC68U [ASUSWRT] VPN OpenVPN Client Config
John Wright
FW 3.0.0.4.380_7378
VPN VyprVPN
The installation went fine after a good swift kick in the binary digits (Reboots)
I have this ASUS error
The WAN IP is not the External IP.
External IP-based services will not work.
Is this a problem? If so, how do I fix it.
John
This usually means that your router is behind another router. The main side effect is you won't be able to forward ports. This will however have no impact on the use of a VPN tunnel to a remote server.
F Router for a VPN with WiFi 7 Routers 6
