RT-AC68U devices to have seperate DNS?
Randy BELL
I have searched the forums and cant quite find what I'm looking for. I am trying to set up a seperate DNS only for my ROKU device and have the rest of the devices on my network have the DNS automatically set by my provider. Is there any way I can do this with the RT-AC68U?
Well, the simplest way would be to leave the router alone and to setup the specific DNS on the ROKU device...:rolleyes:
But I recall that ROKU uses Google DNS by default and only if Google DNS is blocked it will use the routers DNS via DHCP - maybe I am wrong... :oops:
...not sure you can manually set the DNS (like you cannot on Google's Chromecast). :(
1. Set DNS server for ROKU on WAN page
2. Set DNS server for others on LAN - DHCP server page (your ISP dns server)
3. Assign a static ip for ROKU manually (ex: 192.168.1.254)
4. add this rule in /jffs/scripts/firewall-start
iptables -t nat -A PREROUTING -s 192.168.1.254 -p udp --dport 53 -j DNAT --to 192.168.1.1
iptables -t nat -A PREROUTING -s 192.168.1.254 -p tcp --dport 53 -j DNAT --to 192.168.1.1
then only ROKU will use WAN page dns.
Great Ill try it. Where do I input the rule?
