RT-AC68U DLNA problems (not seeing device/disconnecting)
Send a PM to hugo gomez (or me to send you his email) and he will send you a download link if it is available for your model.
Do we know what's the delta between the hgg FW and the rmerlin one? BTW why it's not publicly available I meant hgg - is it because it has some features that are not supposed to be possible to edit? Just would be great to know...
I have some recent logs from minidlna:
upnphttp.c:1354: error: send(res_buf): Broken pipe
upnphttp.c:1186: warn: HTTP Connection closed unexpectedly
The last warn line is keep coming up - assume the client does not close the connection? I started to use an USB stick to watch movies without any interruption which drives me crazy. Anyone any suggestions?
I have seen a few people having issues lately with DLNA either cutting out after 20 mins or not being visible on devices. In some cases including myself it has been resolved by enabling 2 settings in LAN - IPTV
Enable multicast routing (IGMP proxy)
Enable efficient multicast forwarding (IGMP snooping)
Give it a try, it may work for you.
Sony TV doesn't see DLNA media server on ac87u on 5 GHz
https://r.tapatalk.com/shareLink?sh...-server-on-ac87u-on-5-GHz.37152/&share_type=t
