RT AC68U login page not loading.
josh3003
Every few days I've noticed my router login page times out and doesn't load. I have turned off the periodic check for trend micro updates/installs and run a cronjob every day at 4am to restart httpd service. I have to physically power cycle my router to get the login screen to show. Any ideas? Running 384.19
After you flashed to 384.19_0, did you perform a full reset?
If you didn't, I would do so now. In addition to considering upgrading the firmware to the 386.1 base code level, so that you only have to do the reset once too. :)
Best Practice Update/Setup Router/AiMesh Node(s) 2021
I've done that in the past, I've updated now to 386.1 so I'll keep an eye on things.
You are not alone. That also happens with one of my two AC68s, both running rmerlin release 384.18, both clean installs. I have searched this forum several times trying every combination of search terms that I can think of but have found no solution.
I've updated to 386.2_6 and so far no problem with the login page not loading!
Uptime: 18 days 1 hour(s) 52 minute(s) 55 seconds :cool:
