RT-AC68U running 384.16 rebooted randomly
Khadanja
My router just rebooted randomly few minutes ago. I understand it's not a big issue but I was in the middle of something and would like to know why it happened. System logs don't show much info, just shows all services restarting etc or maybe I missed something. Is there a way to find out so I can at least try to make sure it doesn't happen again.
What were you in the middle of? Or is that top secret? :)
Surprised nobody else has responded to you yet.
You may want to look at your NVRAM usage and JFFS usage settings. If almost fully used, this could cause this type of issue.
Are you using any scripts (amtm supported or otherwise)?
What firmware are you using on the router?
NVRAM & JFFS looks ok to me, screenshot attached.
Using amtm scripts only, Diversion & Skynet.
384.16
No issues here, if it happens again maybe try recording all your settings manually (not a config export/import) and factory default then manually config the router.
I have been dirty flashing since the first 384 release...I've only had to factory default when jumping from 382 to 384.
@Khadanja, any reason you're one firmware version behind? :)
