RT-AC68U tools/uptime display loses time -- on CHROME
lighting
I guess this is more a curiosity than a serious problem.
I have an RT-AC86U for my home and office. I've spent the last few weeks struggling with getting rMerlin 384.14_2 on it -- I had random reboots and some other weird behavior with the new code. I switched back to 384.13 a couple of times before I broke down and did a factory reset and manual reconfiguration, which seems to have solved the problem.
In the process I have been monitoring the router's uptime on the GUI Tools page, over hours and even multiple days, to watch for spurious reboots. Now that I don't have reboots I'm surprised to see that the uptime display, left to just click away, runs at a fraction of real time. I had a four hour period this morning when the uptime display advanced by less than two hours (which looks rather as though there was a spurious reboot!). But a reload on the browser brings it up to an accurate count. I've seen this on both 384.13 and 384.14_2.
As I was writing this it occurred to me I should try a different browser. I've been using using Chrome browser on a Mac. Voila! -- no problem with Firefox. Something in the way Chrome is handling the uptime clock field isn't right. I'm going to stop using Chrome, at least for router management duty.
Actually a refresh of the page or even a Ctrl or Shift + F5 on the keyboard.
I recommend installing uptime monitoring (conmon) and perhaps speedtest, that's exactly why I'm using it.
https://github.com/jackyaz/connmon
To my surprise while I noticed my webcam was offline today for 1hr, I can see that uptime monitoring nd speedtest wasn't working since 3 days, ouch :)
I suspect my router must have had several reboots, but possible a bigger issue since both monitoring tools stopped working for so long.
I'm wondering if there is a way to log reboots or if they can be easily viewed and extracted from the syslog?
How would you guys troubleshoot this?
I use scribe, so my log is at /opt/var/log/messages, and any reboot starts with a syslogd message, so
cat /opt/var/log/messages | grep "syslogd started" -B 1
tells me how many restarts are in my current log, and the time it kicked off.
Yours might be at /tmp/syslog.log.
Jan  6 18:21:34 RT-AC86U Mastiff: Got SIGTERM
May  5 01:05:10 syslogd started: BusyBox v1.25.1
Jan 14 15:03:12 RT-AC86U Diversion: disabling services for unmount, from /opt/bin/diversion
Jan 18 08:58:17 RT-AC86U Mastiff: Got SIGTERM
Jan 18 09:00:06 RT-AC86U kernel: nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
Cool, I just installed scribe and will check out the log files soon for reboots.
I wish I could monitor also what processes may take up too much CPU instead of realtime htop.
