George Coat
After a little homework I came down to this two routers on the top of AC1900 group and I would like to ask for your advice.
Which one to buy?
RT-AC68U or R7000?
I noticed several threads comparing these two routers but I think that after firmware, CPU upgrades and retests on SmallNetBuilder it would be worth to look at it again.
My house is with 2 floors and my old D-Link DIR-601-A1 (running DD-WRT v24-sp2 (03/25/13) std
(SVN revision 21061) with TP-LINK Powerline Extender are not good enough anymore to cover my wifi needs in the house.
Ranker shows R7000 on top of the AC1900 group mainly due to the 5GHz performance and range.
Comparing 2.4GHz performance for short distances RT-AC68U looks better in wireless throughput.
But for longer distances R7000 is not only better in 5GHz throughput but also in 2.4GHz throughput and range.
What were the distance locations for those testing conditions?
For the house with 2 floors and currently mostly 2GHz usage, which router would be better choice?
Thank you.
Which one to buy?
RT-AC68U or R7000?
Thank you.
