RT-AC68W: how to restart script after reboot
esojmc
Hello Everyone,
I have a RT-AC68W running the latest version of f/w 3.0.0.4.384_45713. I am using the router as a mini NAS and using it to store shows that hdhomerun records over the air. In order for this to work I have copied the hdhomerun_record_arm and hdhomerun.conf over to the /jffs filesystem and run the command '/jffs/hdhomerun_record_arm start --conf /jffs/hdhomerun.conf' to start the DVR process. Only problem is that a reboot kills the process from running and I need to restart the command manually. I tried creating a cronjob to run the command every hour or so but crons are also not persistent through reboot. Is there anything else I can do to restart this process after a reboot?
Thanks,
Martin
You coulde use Merlin's extended and optimized firmware, yours is exactly the same as an RT-AC68U beside housing-colour, except you would need Aimesh.
