RT-AC86U 384.7_2 & 384.8_beta1 DDNS tunnelbroker Request error
la88962
Dear,
But Asus Oficial Firmware 3.0.0.4.384.32799 is normal
Please Help Me Thanks
What's in your system log when the DDNS request occurs?
Dear,
Nov 19 23:27:29 rc_service: httpd 766:notify_rc restart_ddns
Nov 19 23:27:29 start_ddns: update WWW.TUNNELBROKER.NET [email protected], wan_unit 0
Nov 19 23:27:29 inadyn[1588]: In-a-dyn version 2.5 -- Dynamic DNS update client.
Nov 19 23:27:29 inadyn[1588]: Update forced for alias 502000, new IP# 123.456.78.1
Nov 19 23:27:30 inadyn[1588]: Fatal error in DDNS server response:
Nov 19 23:27:30 inadyn[1588]: [401 NI] badauth
Nov 19 23:27:30 inadyn[1588]: Error response from DDNS server, exiting!
Nov 19 23:27:30 inadyn[1588]: Error code 48: DDNS server response not OK
I just tested it and it's working properly for me.
Nov 19 11:15:33 start_ddns: update WWW.TUNNELBROKER.NET [email protected], wan_unit 0
Nov 19 11:15:33 inadyn[2924]: In-a-dyn version 2.5 -- Dynamic DNS update client.
Nov 19 11:15:34 inadyn[2924]: Update forced for alias 360000, new IP# 1.2.3.4
Nov 19 11:15:34 inadyn[2924]: Updating cache for 360000
Make sure you fill the fields as follow:
hostname: must be your TunnelID (will be a number)
username: your account username
password: must be the update key found on the Advanced tab on the Tunnelbroker page, NOT the account password.
Dear,
I completely set it up with the way you gave me.
I only changed the firmeare,All the settings in the inside are completeiy unchanged.
Asus uses a very old DDNS client, it might possibly be using an older API where the password used was the account password instead of the update key. You will need to change that to also use the update key. The error message clearly says it's an authentication failure.
It wasn't working for me either. But after changing the "User Name or E-mail Address" in DDNS settings page it's working again.
You used to fill in the User ID but that's not working.
Now you have to fill in Account Name which you can find on the account info page (https://tunnelbroker.net/account.php).
Hope this works for you to.......
Thanks for the precisions. I"ll see if I could customize the field names for Tunnelbroker, like I did for Afraid's DDNS.
Dear,
I tried to use account password or Update Key,But all are failures
Dear,
I changed the "User Name and E-mail Address" But all are Request error
"Password or DDNS Key" field should be filled with the update key and the "Hostname" field with Tunnel ID.
"User Name or E-mail Address" should be filled with Account Name.
Must work.......
The username is here:
