RT-AC86U Asuswrt-Merlin torrent does not work
rafagomes
Hi all,
I have a RT-AC86U with merlin firmware v384.10_2, with diversion, stubby and skynet installed and enabled.
I tried to search as much as I could before asking this but all the suggested solutions I could find did not work.
I haven't use torrents in a really long time, but recently I decided to start using again.
The download works perfectly but I cannot seed at all. I tried public and private trackers and I can never seed anything.
I check the UPnP and it is enable, I tried to disable both diversion and skynet and still the seeding does not work.
Does anyone else have any suggestion on what else could I tried?
I use a private tracker and I have to keep a ratio of at least 1.2.
Thanks,
What torrent client are you using ? qBitorrent?
Do you see the ports correctly forwarded in System Log > Port Forwarding?
Any VPNs active?
