RT-AC87U - 384.13_10 : Use openvpn-openssl 2.5.4-1 from entware possible?
Matteo Guglielmi
Dear forum,
despite the router not being supported anymore by merlin's fw, I would need to update the version of my openvpn server.
I noticed that I could install openvpn 2.5.X from entware:
admin@BRTO3:/tmp/home/root# opkg list openvpn-openssl
openvpn-openssl - 2.5.4-1 - Open source VPN solution using OpenSSL
and that openvpn seems to be started using a simple symbolic link which currently points to merlin's openvpn:
admin@BRTO3:/tmp/home/root# ps | grep openvpn
  784 admin     5592 S    /etc/openvpn/vpnserver1 --cd /etc/openvpn/server1 --config config.ovpn
  786 admin     5244 S    /etc/openvpn/vpnserver1 --cd /etc/openvpn/server1 --config config.ovpn
 2803 admin     4728 R    grep openvpn
admin@BRTO3:/tmp/home/root# ll /etc/openvpn/vpnserver1
lrwxrwxrwx    1 admin    root            17 Mar 28 03:02 /etc/openvpn/vpnserver1 -> /usr/sbin/openvpn*
Is there a way to update such link so that it will point to entware's openvpn binary?
Thank you.
You could try creating a /jffs/scripts/openvpnserver1.postconf file as follows:
#!/bin/sh
ln -sf /opt/sbin/openvpn /etc/openvpn/vpnserver1
This assumes that Entware is already mounted when the VPN server starts.
But I don't think this will work as a direct replacement because /opt/sbin/openvpn would need to run against the Entware libraries rather than the default firmware libraries. You might have to move your VPN server config fully over to Entware (/opt/etc/openvpn) and not use the Asus GUI at all.
#!/bin/sh
Well it works but the way Entware compiled openvpn is quite different from merlin's fw way.
In particular, all the following options are set to off in Entware:
enable_iproute2=yes
enable_management=yes
enable_plugin_auth_pam=yes
enable_plugin_down_root=yes
enable_plugins=yes
enable_server=yes
Do you know how to create custom Entware packages?
(I'm currently looking for some howto...)
K Asus rt-ax53u disconnect internet when openvpn server is enabled ASUS Wi-Fi 0
