RT-AC87U FIRMWARE UPGRADE.
KromaZone
Hi all, what is the best way to update the firmware on the above mentioned router? 3 questions below.
should I factory reset then install firmware?
I am a few version behind the latest one....can I skip these and just get the latest version?
and the last question is, what are the benefits of this Merlin 3rd party firmware?
thanks in advance
That is not necessary. But sometimes you need unmount any USB devices (through the GUI), unplug them and reboot to free up memory prior to the upgrade process.
Yes.
Merlin has dropped support for the RT-AC87U so stick with the Asus firmware.
Ok so install the latest fw then factory reset.
I disagree that a factory reset is necessary. You would only normally do so if you were moving to a significantly different firmware version (e.g. 3.0.0.4.380.xxx to 3.0.0.4.382.xxx) or the release notes instruct you to do so.
Can i still upload my saved settings for my router afterwards?
No, that would negate the purpose of the factory reset.
no. You should config all manually. I know that someone can tell You that You can restore settings from older fw, but it's better to configure everything manually. Moment of work, but you know everything will work as it should.
