I've been searching furiously around the net for a similar issue to what I'm getting, but not found any specific remedies. Any advice and help would be gratefully received, before I return this router under warranty (or throw it out the window!).
I've owned an Asus RT-AC87U for about 4 months and had no issue with it until now. My partner text me in work saying "Internet keeps failing". When I get home, I found around every 20m, the router was rebooting. I haven't done anything fancy with this router, I'm running stock firmware and very few of the additional feature, just wifi and that's it.
I've tried the following:
- Turning it on and off (even letting it get cold).
- Upgraded to latest firmware(3.0.0.4.378_9460). Did a full reset and reconfigure.
- Replaced the cables.
It now reboots about every 90 mins, the logs say this (and did before all the attempts to fix):
Feb 12 18:20:51 watchdog02: no wathdog, restarting
Feb 12 18:20:53 kernel: Stop the IPS/AppID engine...
Feb 12 18:20:55 WEBDAV Server: daemon is stoped
Feb 12 18:20:55 NAT Tunnel: AAE Service is stopped
Feb 12 18:20:55 iTunes: daemon is stoped
Feb 12 18:20:55 FTP Server: daemon is stoped
Feb 12 18:20:55 Samba Server: smb daemon is stoped
Feb 12 18:20:55 kernel: gro disabled
Feb 12 18:20:55 Timemachine: daemon is stoped
Feb 12 18:20:55 disk_monitor: Finish
Feb 12 18:20:55 miniupnpd[8213]: shutting down MiniUPnPd
Feb 12 18:20:56 NAT Tunnel: AAE Service is stopped
Feb 12 18:20:58 kernel: Attempt to kill tasklet from interrupt
Feb 12 18:20:59 WAN Connection: Fail to connect with some issues.
Feb 12 18:20:59 DualWAN: skip single wan wan_led_control - WANRED off
Feb 12 18:20:59 stop_nat_rules: apply the redirect_rules!
Feb 12 18:21:01 watchdog02: no wathdog, restarting
Feb 12 18:21:02 wanduck exit: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Feb 12 18:21:04 kernel: klogd: exiting
Feb 12 18:21:04 syslogd exiting
The reboot appears to start from the first line: watchdog02: no wathdog, restarting.
Why this is occurring, I've no idea. I have access to SSH if there are some other logs I can look at?
I'm thinking it's a hardware issue, as one day it was fine, the next it's persistently rebooting. I've read on forums this router suffers with overheating; I'm running the stock ASUS firmware, could this still be an issue?
If nobody can help, I'll send it back under warranty for replacement/repair.
Thanks in advance
Dave
Thanks in advance
Dave
