RT-AC88U constant issues with speed
mike929
I ready to dump my RT-AC88U. It is killing my internet speeds. I'm getting 1-4Mbps download. I am on Comcast 300MB download plan. I have to constantly reboot everything and change cables. If I can't get help I need to get something else. I purchased this 11/24/16 any options for return? Also what router out now should I get based on this model my needs should seem transparent. Looking for TOP tier routers.
Speed Results
DOWNLOAD SPEED
4.63 Mbps
UPLOAD SPEED
29.54 Mbps
When directly connected to Modem speed is fine. Running cat6 cable to modem and laptop.
Router is stock - Firmware Version:3.0.0.4.380_7743
Signature Version
1.174
Thanks in advance,
Mike
The 88 is a good router so what ever is going on is either hardware or configuration. Have you factory reset the router and started over by manually entering your settings ? Start with basic settings and test along the way.
I've done that once before. I have a lot of port forwarding for security cams, static IP address for devices. That is a pain to input all that info all over again. This keeps happening with this router. I bought because I that it was good or the best. I have 30+ devices on my network wired and wireless. QOS for gaming is enabled.
I understand trouble shooting can be time consuming and a pain in the butt. But sometimes needed. Did you try completely disabling QOS and test ? Knock off the other clients and only use one known good computer for testing.
I just changed the modem to router cable ( another cat6 cable ). I didn't reboot anything just changed the cable. 2nd time i've had to do this. The modem and router are less than 2ft apart.
xbox was getting 1.3 download. I had to reboot it/power off and now it's getting 250.55 down and 29.71 up.
If your cable modem is also a router combo make sure it is in bridge mode. I see this daily where people think they can just plug a router into a router/modem and expect it to work properly.
I have a Arris 6190. I want to move to gig speed, that will require a new modem.
Sent from my SM-N910P using Tapatalk
