RT-AC88U only 4 Switch Ports available, failed to load...
Marco Kohler
Hi
Since I tested a rt-ac88u beta from dd-wrt. After a while I went back to original Firmware.
Since this test, only Port 1-4 are coming up, port 5-8 are since then down. In the syslog I can find following messages:
Aug 1 01:00:16 kernel: rtl8365mbrtl8365mb initialized(14)(retry:10) failed
Aug 1 01:00:16 kernel: rtk port_phyEnableAll Failed!(15)
Aug 1 01:00:16 kernel: rtk port_macForceLink_set ext_Port0 Failed!(15)
Aug 1 01:00:16 kernel: register rtl8365mb done (link down at first)
I always did a factory reset, deleted nvram and some else. I also testet with asuswrt-merlin Firmware. Same result.
Does anyone has a hint for me or did I brick the device?
Best,
Marco
Hi
Best,
Marco
I've got the exact same problem as you describe. Just wondering what you ended up doing to hopefully fix it?
Just an update, I bought it back to the store and swapped it over for a brand new one. Apparently this issue does happen, albeit rare in ASUS routers but technology can fail in any case. Definitely a hardware issue as opposed to software. If you haven't had it for a year you can bring it back for a new one. Hope that helps you out.
