RT-AX11000 vpn server and client (fusion)
Tuneboy2005
hello,
while experimenting further with my new ax11000 i have a problem with using vpn server and client (fusion) at the same time. i had it all working on my old RT-AC68u. The AC68u was connected to my vpn subscription while my vpn server was also running. I could use them both at the same time with beneath settings (policy rules) see first screenshot
https://snag.gy/KCYqpG.jpg
so all my clients at home where using the tunnel. At the same time i could access my lan clients when i was outside my house.
Now with my new ax11000 i cant seem to use them at the same time. in next screenshot https://snag.gy/HcIi5x.jpg when the blue dot is above (internet) my vpn subscription is disabled but my server is running great and can access all my clients from outside the house. When i set the blue dot on airvpn (and enable) my subscription is running great and all my clients are behind the tunnel but i cant connect anymore from outside my house to my server. Is it because i can not set the following rule
192.168.2.1/24. the firmware of the ax11000 doesn not accept /24
i have to select from the list my clients and choose weather they are going to use the tunnel or not.
thx in advance
greetz
I want to bring up this topic. Since i cant get this working i contacted Asus support. They simply said that this is not going to work, use fusion and server at the same time. You can only use one at a time.
This sucks because on my old 160€ RT-AC68U it worked very good but on my 400€ brand new AX11000 this is not working. kinda dissapointed.
Just want to let you know.
