I have a brand new 4 day old RT-AX56U and it crashed while running Asus Merlin 386.4 alpha1. I am running no scripts and have a pretty simple configuration as in my signature (2 guest networks using Guest Network 1 on each band, 2 main networks, DNS over TLS, IPv6).
Prior to the crash, I was streaming a movie on the 5Ghz guest network. CPU load is very low always on this router and CPU temp runs 50 - 60 degrees C. After the crash, 2 Wyze cameras that I have could no longer connect to the 5Ghz guest network despite power cycling the cameras and other troubleshooting. I rolled back to 386.2.2 to be able to connect those devices again.
I would appreciate someone with more knowledge than I have to dissect the crash log as to what may have happened.
