peevesillinois
Hello!
For the past few days, I've been trying to figure out why RT-AX58U is unable to link to my IFTTT-account.
After generating an activation code in the admin-gui, I head over to https://ifttt.com/asusrouter and hit "connect".
So far so good. Then I paste my activation code and hit "Activate". After a few seconds, the activation fails and I get a error hint stating that I need to verify that my DDNS and WAN-access are enabled. It seems to be a general error pre-rendered in the HTML-markup. So I don't believe that is very accurate.
It says "Please check the following settings: Enable DDNS, Enable Web Access from WAN".
As far as I'm concerned, these settings are configured correctly from my end.
I have tried the following:
I've monitored the system log in the RT-AX58U, but nothing is recorded there during the activation.
What can I do next?
Best Regards /
J
These are my current WAN and DDNS-settings:
- Reinstalled latest the asuswrt firmware (3.0.0.4.386_48631)
- Used a different DDNS provider besides asuscomm.com (I Tried noip.com)
- Tried both with/without SSL enabled on the DDNS
- Port forwarding on/off
- Factory reset of the RT-AX58U
- Created another IFTTT-account
- Tested the linking procedure from multiple browsers/devices
What can I do next?
Best Regards /
J
