RT-AX82U upgrade
tiomiguel
As known, I am thinking in upgrading my RT-AX82U because I need about 200 Mb in WIREGUARD and this device is not able to do that. It does about 100-120 Mb
I have installed GNUTON firmware and device is now solid like a rock, with PERFECT IOT WIFI now -in the past I had problems with some dvices- BU NOW NO PROBLEM. In WIREGUARD I see BCM6750 can not do more.
I can:
1) Change to a more powerful router: I have Rt-AX59U at 80 euro and TUF-AX4200 (ugly gui) about 90 euro. These can do WIREGUARD as I want. Both wear FILOGIC 830, very powefull, but these products are near EOL? What is the ASUS long time support for MEDIATEK PRODUCTS? What to choose between both, If I had to choose?
2) At about 80 euro TUF AX3000 V2 with BCM 6756 (4 cores at 1,7 Ghz) vs BCM6750 (3 cores at 1,5 Ghz). PERHAPS WIREGUARD will improve enough for me (I DO NOT KNOW), and AX3000V2 can wear GNUTON firmware -I like this GUI-. Perhaps this firmware will do longer support than ASUS for MEDIATEK... But Perhaps is stupid purchasing this product if RT-AX59U is at the same price.
So, please, I NEED ADVICE
¿What to choose? RT-AX82U would continue workig -has great WIFI performance- in AP mode -or perhaps in INMESH node-
I told you what model router you need, but you continue asking for different models because they are cheaper. Good luck!
