RT-AX86U disconnects, slow speeds
ibrubeer
I am trying to troubleshoot this whole thing. I have been having speed problems with the internet for a while. I used to have an older Asus router (RT-AC87R) and bought a new one to see if that fixed the problem. The new one is an RT-AX86U. Internet speeds are largely the same. The internet will randomly and intermittently disconnect, and then reconnect. I don't see anything in the system logs, but I am not exactly sure what I am looking at. Can anybody see anything in here that could help point me in the right direction?
Sep 13 11:38:54 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=185.191.34.205 DST=**.***.***.** LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=34614 PROTO=TCP SPT=48989 DPT=7105 SEQ=3889445348 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Sep 13 11:39:00 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=162.245.236.122 DST=**.***.***.** LEN=430 TOS=0x00 PREC=0x00 TTL=53 ID=2287 DF PROTO=UDP SPT=5142 DPT=5060 LEN=410 MARK=0x8000000
Sep 13 11:39:02 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=193.27.228.64 DST=**.***.***.** LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=52468 PROTO=TCP SPT=55893 DPT=39349 SEQ=3939168338 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Sep 13 11:39:06 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=89.248.165.48 DST=**.***.***.** LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=54321 PROTO=TCP SPT=51419 DPT=8443 SEQ=1783653350 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
Sep 13 11:39:08 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=45.143.203.2 DST=**.***.***.** LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=64323 PROTO=TCP SPT=43082 DPT=3378 SEQ=3162264418 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Sep 13 11:39:09 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=8.140.103.54 DST=**.***.***.** LEN=60 TOS=0x00 PREC=0x00 TTL=49 ID=11711 DF PROTO=TCP SPT=43368 DPT=2419 SEQ=2167304123 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AF948851C0000000001030307) MARK=0x8000000
Sep 13 11:39:10 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=8.140.103.54 DST=**.***.***.** LEN=60 TOS=0x00 PREC=0x00 TTL=49 ID=11712 DF PROTO=TCP SPT=43368 DPT=2419 SEQ=2167304123 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AF94889200000000001030307) MARK=0x8000000
Sep 13 11:39:11 kernel: wl0: random key value: F83957D9BE96E9FF5E4D009952E86043DFD65150668A0532D222BFDDEAF23679
Sep 13 11:39:11 wlceventd: wlceventd_proc_event(486): eth6: Disassoc 18:B4:30:8C:80:45, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Sep 13 11:39:12 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=8.140.103.54 DST=**.***.***.** LEN=60 TOS=0x00 PREC=0x00 TTL=49 ID=11713 DF PROTO=TCP SPT=43368 DPT=2419 SEQ=2167304123 ACK=0 WINDOW=64240 RES=0x00 SYN URGP=0 OPT (020405B40402080AF94891000000000001030307) MARK=0x8000000
Sep 13 11:39:29 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=89.248.165.48 DST=**.***.***.** LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=54321 PROTO=TCP SPT=40539 DPT=8080 SEQ=582680555 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
Sep 13 11:39:34 wlceventd: wlceventd_proc_event(505): eth6: Auth 18:B4:30:8C:80:45, status: Successful (0)
Sep 13 11:39:34 wlceventd: wlceventd_proc_event(534): eth6: Assoc 18:B4:30:8C:80:45, status: Successful (0)
Sep 13 11:39:39 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=93.148.109.143 DST=**.***.***.** LEN=52 TOS=0x00 PREC=0x00 TTL=108 ID=32560 DF PROTO=TCP SPT=59255 DPT=1433 SEQ=45574530 ACK=0 WINDOW=8192 RES=0x00 SYN URGP=0 OPT (020405AC0103030201010402) MARK=0x8000000
Sep 13 11:39:44 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=221.181.185.143 DST=**.***.***.** LEN=40 TOS=0x00 PREC=0x00 TTL=232 ID=30079 PROTO=TCP SPT=9090 DPT=22 SEQ=30000 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
Sep 13 11:39:46 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=89.248.165.104 DST=**.***.***.** LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=3473 PROTO=TCP SPT=40135 DPT=13579 SEQ=967679369 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Sep 13 11:40:25 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=205.185.115.123 DST=**.***.***.** LEN=44 TOS=0x00 PREC=0x00 TTL=248 ID=54321 PROTO=TCP SPT=37160 DPT=60001 SEQ=23387586 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (02040218) MARK=0x8000000
Sep 13 11:40:30 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=74.120.14.83 DST=**.***.***.** LEN=44 TOS=0x00 PREC=0x20 TTL=42 ID=6339 PROTO=TCP SPT=31963 DPT=12269 SEQ=2578780922 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 OPT (020405B4) MARK=0x8000000
Sep 13 11:41:11 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=89.248.165.170 DST=**.***.***.** LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=54321 PROTO=TCP SPT=41685 DPT=8332 SEQ=3664597464 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
Sep 13 11:41:30 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=103.145.13.243 DST=**.***.***.** LEN=40 TOS=0x00 PREC=0x00 TTL=238 ID=35943 PROTO=TCP SPT=48816 DPT=5038 SEQ=4214635226 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Sep 13 11:41:30 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=142.250.191.106 DST=**.***.***.** LEN=679 TOS=0x00 PREC=0x00 TTL=61 ID=55295 PROTO=TCP SPT=443 DPT=64447 SEQ=1704995119 ACK=2604044218 WINDOW=265 RES=0x00 ACK PSH URGP=0 MARK=0x8000000
Sep 13 11:42:01 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=142.250.191.106 DST=**.***.***.** LEN=679 TOS=0x00 PREC=0x00 TTL=61 ID=7840 PROTO=TCP SPT=443 DPT=64447 SEQ=1704995119 ACK=2604044218 WINDOW=265 RES=0x00 ACK PSH URGP=0 MARK=0x8000000
Sep 13 11:42:08 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=190.141.86.72 DST=**.***.***.** LEN=60 TOS=0x00 PREC=0x00 TTL=53 ID=19046 DF PROTO=TCP SPT=47430 DPT=5555 SEQ=1812331680 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40402080A0041B6C60000000001030306) MARK=0x8000000
Sep 13 11:42:09 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=190.141.86.72 DST=**.***.***.** LEN=60 TOS=0x00 PREC=0x00 TTL=53 ID=19047 DF PROTO=TCP SPT=47430 DPT=5555 SEQ=1812331680 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40402080A0041B72A0000000001030306) MARK=0x8000000
Sep 13 11:42:11 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=190.141.86.72 DST=**.***.***.** LEN=60 TOS=0x00 PREC=0x00 TTL=53 ID=19048 DF PROTO=TCP SPT=47430 DPT=5555 SEQ=1812331680 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B40402080A0041B7F20000000001030306) MARK=0x8000000
Sep 13 11:42:15 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=64.62.197.229 DST=**.***.***.** LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=54321 PROTO=TCP SPT=41276 DPT=8080 SEQ=2685699392 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
Sep 13 11:42:21 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=167.248.133.89 DST=**.***.***.** LEN=44 TOS=0x00 PREC=0x00 TTL=38 ID=32825 PROTO=TCP SPT=60499 DPT=12193 SEQ=3453503890 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 OPT (020405B4) MARK=0x8000000
Sep 13 11:42:31 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=142.250.191.106 DST=**.***.***.** LEN=679 TOS=0x00 PREC=0x00 TTL=61 ID=25458 PROTO=TCP SPT=443 DPT=64447 SEQ=1704995119 ACK=2604044218 WINDOW=265 RES=0x00 ACK PSH URGP=0 MARK=0x8000000
Sep 13 11:42:42 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:92:bd:b0:74:8e:f8:a7:3b:c1:08:00 SRC=114.202.248.49 DST=**.***.***.** LEN=40 TOS=0x00 PREC=0x00 TTL=50 ID=56784 PROTO=TCP SPT=61761 DPT=23 SEQ=1123132691 ACK=0 WINDOW=59993 RES=0x00 SYN URGP=0 MARK=0x8000000
Turn off logging of dropped packets. We can't see anything useful when the syslog is being flooded with these entries.
Log into your modem (not the router) and look at its log for indications if/why the internet connection drops.
You need to give us more information:
Firmware Asus or Merlin and what version (If you have not upgraded the firmware, you should!).
Bandwidth expected from ISP and type (DSL, cable or FIOS)
Speed problems where, Wired or WIFI?
WIFI settings used?
WIFI settings used?
Sorry. Here is some hopefully better information
- RT-AX86U router running Merlin firmware, version 386.3_2
- Speed from ISP is max 25Mbps, DSL
- Speed problems are wired and wireless. It seems that it was initially good after installing the router, and using the M&M configuration
- Attached are screenshots of my wireless settings.
- Attached is also a section of the latest system log this morning
Thank you for any help you can provide to get me pointed in the correct direction.
  • syslog 09152021_1002 sample.txt
Sep 15 03:51:32 WAN_Connection: ISP's DHCP did not function properly.
Sep 15 03:51:35 wan: finish adding multi routes
Sep 15 03:51:35 dhcp_client: bound 66.241.165.19/255.255.254.0 via 66.241.164.1 for 1684 seconds.
Sep 15 03:51:37 WAN_Connection: WAN was restored.
I guess there you have an indication. Is your router directly connected to the WAN?
Besides that - when you had the same issue with your ISP on the old router and now the same on the new router should be a hint that it might be your ISP as the troublemaker? :)
No, my router is not directly connected to the WAN. It is connected to a modem first. Is this a setting that is wrong in my router, or with my ISP then?
look at the post @ColinTaylor he said that you should login in to your modem and look at the logs there. I guess the log which you attached was from your router and not the modem. May be you find more information on the issue on your modems log.
To make the above quote more clear for you:
This is what most people have here - a modem to connect to the ISP and a home router. The modem is connected to the WAN port of the router. This "WAN_Connection" in logs is your Wide Area Network connection, through the modem to your ISP and out in the wild. The ISP assigns an IP to your router, similar to how your router assigns IPs to your devices on your LAN - Local Area Network. When something goes wrong and your router can't get an IP from your ISP, you get the message "ISP's DHCP did not function properly".
