RT-AX86U, RT-AX68U to 388.1 firmware, aimesh now shows no ethernet uplink
sergeant-smooove
Hi all,
I have a potential aimesh issue since upgrading to asus-merlin 388.1, and I would really appreciate if you have any suggestions on how to resolve it.
In my house I have an aimesh network consisting of an RT-AX86U in my front room that acts as the primary router, and two RT-AX68Us in my attic and garden studio that are connected to the RT-AX86U via ethernet cable.
I upgraded the firmware of all devices from 387.x to 388.1. It looks like this may have caused issues with the ethernet connection between the primary router and the node:
- In the web portal, aimesh tab, the diagram went from showing green lines between the router and nodes to grey lines with crosses over them
- When I click on each AI node, it says the connection quality is 'Great' but also shows a red speech bubble which contains the warning 'Your AiMesh node cannot connect to your uplink AiMesh device. Ensure that both devices have been powered on. If your node still fails to connect, power cycle your devices and move them closer to each other'
- When I click on the Network tab of each aimesh node,it gives the uplink type of Ethernet but then displays a red cross on the diagram
However, all devices have clients connected to them, and show ethernet transmit/receive stats, so I'm not sure if there is an actual issue with the ethernet connection, although my family have been regularly complaining about the wifi connection and ability to connect to the internet (in the main house, i.e. where the main router and Attic node are).
Do you think I have a connection issue? If so, can you suggest how I can resolve the issue? I've tried resetting the two nodes and reconnecting but it hasn't helped. I could reset the primary router, if you think it will help.
Any help appreciated
Sergeant-smoove
Have you tried using Merlin in the main router and AsusWRT in the nodes? For some reason, this combination tends to work better than all Merlin.
Discussed in Asuswrt-Merlin 388.1 release thread and well known issue. There are other potential AiMesh issues with Asuswrt-Merlin.
