RT-AX86U Update won't progress
RebelAngel
Hi, I just downloaded the latest 388.1 update and tried to install the usual way, but it won't work. Looks like it doesn't upload the file to the Router. It's stuck on "Bitte warten, fortfahren..." / "Please wait, proceeding...". I already tried to download the file from the mirror in case the download is corrupt, but the result is just the same...any idea what might cause the problem? :-/
Try changing the language to English, reboot the router (be sure to also remove any USB devices), then try again.
There is no soft-reset.
What does that mean for you?
