RT-AX88U Asus App
Harvey84
Hello,
I have an RT-AX88U router flashed with Merlin. However when using the Asus App (android) I cannot find the router. Just wondering if it's because I have flashed the router or if it's just the app?
Thanks any guidance will be much appreciated.
Rick
I hadn't installed or used the app before, but I installed it to see. It found my AX88U running Merlin v384.18 right away.
Are you on the same subnet as the router (not on a VPN, on internal lan, router is default gateway, etc) and not on a guest network or have any other "security" scripts running?
Hello,
Yes, I am in the same subnet and not aware of any "security" script running.
However this morning the app found the router and now all set up. Guess there must have been a delay after the initial setup of the router and all was needed was a little patience.
Thanks for the reply.
