For 1), what does 'manually reset the router' mean, specifically, to you?
As in reach behind it, turn off the router and turn it back on. We JUST had another outage and the log for today is pretty specific to only around the time it happened. Here's today's log entries around the time it happened (oddly the log is not fully date ordered for some reason--there are March 11 entries then March 5 entries and then more March 11 entries):
Mar 11 13:43:32 rc_service: ntp 1430:notify_rc restart_diskmon
Mar 11 13:43:32 disk_monitor: Finish
Mar 11 13:43:32 disk monitor: be idle
Mar 11 13:43:32 wlceventd: wlceventd_proc_event(427): eth7: Auth FC:A1:83:1E:0E:02, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:32 wlceventd: wlceventd_proc_event(455): eth7: Assoc FC:A1:83:1E:0E:02, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:33 wlceventd: wlceventd_proc_event(427): eth6: Auth 00:04:20:F5:75:C6, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:33 wlceventd: wlceventd_proc_event(455): eth6: Assoc 00:04:20:F5:75:C6, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:34 wlceventd: wlceventd_proc_event(427): eth7: Auth 68:9A:87:5B:7D:EC, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:34 wlceventd: wlceventd_proc_event(455): eth7: Assoc 68:9A:87:5B:7D:EC, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:34 wlceventd: wlceventd_proc_event(409): eth6: Disassoc EC:FA:BC:48:C7:8B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Mar 11 13:43:36 kernel: SHN Release Version: 2.0.1 0679c74
Mar 11 13:43:36 kernel: UDB Core Version: 0.2.18
Mar 11 13:43:36 kernel: sizeof forward pkt param = 280
Mar 11 13:43:36 BWDPI: fun bitmap = 3
Mar 11 13:43:36 wlceventd: wlceventd_proc_event(427): eth6: Auth EC:FA:BC:48:C7:8B, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:36 wlceventd: wlceventd_proc_event(455): eth6: Assoc EC:FA:BC:48:C7:8B, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:37 wlceventd: wlceventd_proc_event(427): eth7: Auth F8:54:B8:60:BF:5C, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:37 wlceventd: wlceventd_proc_event(455): eth7: Assoc F8:54:B8:60:BF:5C, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:38 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Mar 11 13:43:38 dhcp client: bound 71.187.94.135/255.255.255.0 via 71.187.94.1 for 7200 seconds.
Mar 11 13:43:40 wlceventd: wlceventd_proc_event(392): eth7: Deauth_ind FC:A1:83:07:B8:20, status: 0, reason: Unspecified reason (1)
Mar 11 13:43:40 wlceventd: wlceventd_proc_event(427): eth7: Auth FC:A1:83:07:B8:20, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:40 wlceventd: wlceventd_proc_event(455): eth7: Assoc FC:A1:83:07:B8:20, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:43 wlceventd: wlceventd_proc_event(427): eth6: Auth 44:61:32:CB:27:F3, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:43 wlceventd: wlceventd_proc_event(455): eth6: Assoc 44:61:32:CB:27:F3, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:45 wlceventd: wlceventd_proc_event(392): eth6: Deauth_ind 2C:F4:32:82:C6:7D, status: 0, reason: Unspecified reason (1)
Mar 11 13:43:45 wlceventd: wlceventd_proc_event(427): eth6: Auth 2C:F4:32:82:C6:7D, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:45 wlceventd: wlceventd_proc_event(455): eth6: Assoc 2C:F4:32:82:C6:7D, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:48 kernel: ubi1: attaching mtd10
Mar 11 13:43:48 kernel: ubi1: scanning is finished
Mar 11 13:43:48 kernel: ubi1: attached mtd10 (name "misc1", size 8 MiB)
Mar 11 13:43:48 kernel: ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Mar 11 13:43:48 kernel: ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Mar 11 13:43:48 kernel: ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
Mar 11 13:43:48 kernel: ubi1: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
Mar 11 13:43:48 kernel: ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
Mar 11 13:43:48 kernel: ubi1: max/mean erase counter: 6/2, WL threshold: 4096, image sequence number: 527176359
Mar 11 13:43:48 kernel: ubi1: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 4
Mar 11 13:43:48 kernel: ubi1: background thread "ubi_bgt1d" started, PID 1922
Mar 11 13:43:49 kernel: ubi: mtd10 is already attached to ubi1
Mar 11 13:43:49 kernel: UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 1974
Mar 11 13:43:49 kernel: UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "nvram"
Mar 11 13:43:49 kernel: UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Mar 11 13:43:49 kernel: UBIFS (ubi1:0): FS size: 5840896 bytes (5 MiB, 46 LEBs), journal size 1396736 bytes (1 MiB, 11 LEBs)
Mar 11 13:43:49 kernel: UBIFS (ubi1:0): reserved for root: 0 bytes (0 KiB)
Mar 11 13:43:49 kernel: UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 2A6BEA28-491B-4503-A426-8F74D62305AF, small LPT model
Mar 11 13:43:54 wlceventd: wlceventd_proc_event(427): eth7: Auth 50:F5
A:34:C0:F1, status: 0, reason: d11 RC reserved (0)
Mar 11 13:43:54 wlceventd: wlceventd_proc_event(455): eth7: Assoc 50:F5
Mar 11 13:44:01 wlceventd: wlceventd_proc_event(427): eth7: Auth 00:BB:3A:B4:28:39, status: 0, reason: d11 RC reserved (0)
Mar 11 13:44:01 wlceventd: wlceventd_proc_event(455): eth7: Assoc 00:BB:3A:B4:28:39, status: 0, reason: d11 RC reserved (0)
Mar 11 13:44:09 crond[1136]: time disparity of 974199 minutes detected
Mar 11 13:44:36 wlceventd: wlceventd_proc_event(427): eth7: Auth D4:4D:A4:C6:E3:0A, status: 0, reason: d11 RC reserved (0)
Mar 11 13:44:36 wlceventd: wlceventd_proc_event(455): eth7: Assoc D4:4D:A4:C6:E3:0A, status: 0, reason: d11 RC reserved (0)
Mar 11 13:44:37 kernel: bcm_i2c: bus 0: Failed to detect SFP: 100 retries exhausted
Mar 11 13:44:48 WATCHDOG: [FAUPGRADE][auto_firmware_check
6148)]period_retry = 0
6154)]periodic_check AM 5:40
6177)]retrieve firmware information
6180)]user in use
Mar 11 13:45:18 hour monitor: ntp sync fail, will retry after 120 sec
Mar 11 13:47:03 wlceventd: wlceventd_proc_event(427): eth7: Auth 00:9D:6B:10:4D:82, status: 0, reason: d11 RC reserved (0)
Mar 11 13:47:03 wlceventd: wlceventd_proc_event(455): eth7: Assoc 00:9D:6B:10:4D:82, status: 0, reason: d11 RC reserved (0)
Mar 11 13:49:56 miniupnpd[1449]: PCP MAP: added mapping TCP 23260->192.168.1.22:23260 'PCP MAP 214f713dc23928d1b82d0c54'
Mar 11 13:49:56 miniupnpd[1449]: PCP MAP: added mapping UDP 23260->192.168.1.22:23260 'PCP MAP 163588281058ccc3d3407b4f'
Mar 11 13:52:32 miniupnpd[1449]: PCP MAP: added mapping UDP 7962->192.168.1.50:7962 'PCP MAP e987fe3d4aeb18b80d30e2c4'
Mar 11 13:52:32 miniupnpd[1449]: PCP MAP: added mapping TCP 8080->192.168.1.50:8080 'PCP MAP ee7a568da7fb0ae5902286c3'
