Are you running any addon scripts? If so which ones?Router in router mode. Passes about 6TB per month. Traffic monitor works for about 35 days and stops working. Turning off, clearing and turning on does not help.
Asus Merlin firmware 3004.388.7
1. No. No scripts.Are you running any addon scripts? If so which ones?
Does rebooting the router fix the issue for a period of time?
Does rolling back to earlier firmware fix the issue?
Maybe you don't have that much traffic. I have 6TB a month. That's probably why I have this bug.But haven't had any problems of any kind with 388.8_2 fresh install on RT-AX88U nor RT-AX88U Pro version...
No. I need an official fix, not experimentation. I don't have the ability to experiment.Have you tried installing the latest Merlin fw 388.8_2
That is the Traffic Analyzer not the Traffic Monitor. They are two completely different things. The Traffic Analyzer is closed source so there's nothing RMerlin can do to fix it. You need to complain to Asus.Traffic monitor is not working again on firmware 3004.388.8_4. But now after 10TB. It's resetting. Please fix it.View attachment 66488
@RMerlin help please
Welcome To SNBForums
