Release RT-AX89X firmware 3.0.0.4.386.23012
doc octopus
ASUS RT-AX89X Firmware version 3.0.0.4.386.23012
- Improved system stability.
- Fixed GUI bugs.
- Security Fixed: CVE-2020-25681, CVE-2020-25682, CVE-2020-25683, CVE-2020-25687, CVE-2020-25684, CVE-2020-25685, CVE-2020-25686
Problem detected in this version:
- Xbox Series X fails to connect to DFS channels (with other routers it does)
- Bandwidth Monitor shows bad values, higher than those physically possible on my connection
- Oppo Reno 2 can't connect to the 5 GHz band
- Google Chromecast 4K sometimes does not connect to the 5 GHz band
Luc Duguay
ASUS RT-AX89X Firmware version 3.0.0.4.386.23012 broke IPTV for me.
Looks like ICMP Snooping is disabled, When that happens I get the usual 10 sec of TV then image freeze issue.
Back to 3.0.0.4.386_22790
Fizix
- Fixed GUI bugs.
The only thing I have noticed so far is this minor repeat on the "Operation Mode"
L&LD
Part of the Furniture
Did you reboot?
Fizix
Yes, I rebooted, but it did not remove it.
Does not affect operation in any way that I can discern.
L&LD
To clarify, did you reboot both the router and the client device/browser you were using? Or, at least clear the browser cache on that device (as a test)?
doc octopus
This problem does not give me
Instead, I would like to point out some problems I encountered:
doc octopus
Update:
