RT-N66R/U: Can't manually assign IP addresses to AP's
wnhs
I'm running firmware version 3.0.0.4.376_1071 on a RT-N66R, which is my primary router. I have two others set up in AP mode. One of them, which I set up about a year ago, has a static address -- I reserved it using the DHCP router's manual IP assignment feature. However, I just added the second AP this weekend and when I try the same thing (go into the MAC address table, select the AP, assign the IP, add to table and save), the DHCP router hangs indefinitely and nothing happens.
I have tried power cycling and reinstalling the firmware but nothing seems to help. Has anyone else experienced this problem?
Thanks!
Actually, I can't make any changes to the router at all. Seems as though it was bricked somehow. Will have to investigate further...
I had the same issue after I firmware upgraded it the first time. I did a factory reset of the settings and that solved the problem.
