[RT-N66U 380.58] Cannot set channel to 12 or 13 in the 2.4GHz band
episyron
I tried to change the control channel to more quiet 13 in the wireless 2.4GHz band, but although 12 and 13 control channels are on the list to be selected, after selecting 13 the control channel changes to Auto (and picks the channel 6) and a channel bandwidth changes from 20Hz to 20/40Hz. So they seem to reset to defaults. The wireless mode was before and after Auto. Channels 12 and 13 are legitimate channels in this part of the world. To my eye there seems to be nothing relevant in the system log:
Apr 26 11:57:36 rc_service: httpd 258:notify_rc restart_wireless
Apr 26 11:57:37 kernel: br0: port 2(eth1) entering disabled state
Apr 26 11:57:37 kernel: device eth1 left promiscuous mode
Apr 26 11:57:38 kernel: br0: port 3(eth2) entering disabled state
Apr 26 11:57:38 kernel: device eth2 left promiscuous mode
Apr 26 11:57:38 kernel: br0: port 4(wl0.1) entering disabled state
Apr 26 11:57:38 kernel: device wl0.1 left promiscuous mode
Apr 26 11:57:38 kernel: br0: port 5(wl1.1) entering disabled state
Apr 26 11:57:38 kernel: device wl1.1 left promiscuous mode
Apr 26 11:57:38 kernel: wl_module_init: passivemode set to 0x0
Apr 26 11:57:38 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Apr 26 11:57:38 kernel: eth2: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Apr 26 11:57:39 kernel: device eth1 entered promiscuous mode
Apr 26 11:57:39 kernel: br0: port 2(eth1) entering learning state
Apr 26 11:57:39 kernel: br0: topology change detected, propagating
Apr 26 11:57:39 kernel: br0: port 2(eth1) entering forwarding state
Apr 26 11:57:39 kernel: device eth2 entered promiscuous mode
Apr 26 11:57:39 kernel: br0: port 3(eth2) entering learning state
Apr 26 11:57:39 kernel: br0: port 3(eth2) entering forwarding state
Apr 26 11:57:39 kernel: device wl0.1 entered promiscuous mode
Apr 26 11:57:39 kernel: br0: port 4(wl0.1) entering learning state
Apr 26 11:57:39 kernel: br0: port 4(wl0.1) entering forwarding state
Apr 26 11:57:39 kernel: device wl1.1 entered promiscuous mode
Apr 26 11:57:39 kernel: br0: port 5(wl1.1) entering learning state
Apr 26 11:57:39 kernel: br0: port 5(wl1.1) entering forwarding state
but are the adapter capable of it
we recommend not using ch 12 or 13 because of incompatibility issues with client adapters
if 2.4 gig is that noisy use 5 gig as thats what its there for , if your clients are only 2.4 gig its prob time to upgrade them
I have never run into an adapter thats incapable of using channel 12 and 13
it may cause issues for users using that use channel illegally but for people in the correct region
its fine (the adapter usually polls the os region)
Try these settings
Actually I have used channel 13 for long time successfully with my clients and a stock ASUS firmware. It is quite nice to have channel 13 available, having 4 non-overlapping channels instead of 3. I had to change the channel as Raspberry Pi 3 didn't support upper channels at first. Well now it is fixed in RasPi3 so it was time to change the channel back to 13 and in the mean time I upgraded to merlin 380.58.
I am more than willing to change to 5GHz, but in this household there are too many clients in 2.4GHz to make total switch, regret to say even new hardware. But I'm not gonna go back to the ASUS factory firmware for this, preferring merlin's...
the use of ch 12 and 13 are of little use in avoiding congesting as they overlap ch 11 , there are only 3 usable channels that do not overlap and thats ch 1 , 6 or 11
as above ch 12 and 13 overlap ch 11 , so its not a 4th non overlapping setup
it is only non overlapping if ch 14 is selected which is only available in japan and thats if 20 mhz is selected
There is only 2 non overlapping channels for 40mhz in an eu region
1 Above or 5 Below
and
13 Below or 9 Above
for the US there's no way to not overlap.
There is plenty reason to use channel 13 people in the eu tend to not use 11 at all
and that still overlaps with ch 11 so your argument doesnt stand up , it is still overlapping on 20mhz
again the choice of ch 12 or 13 does not and will not give you a 3rd or 4th non overlapping channel set and so the reason to choose it has no validity
Your thinking as an american
if you had access to 1-13
the recomended channels would be as i said
there's 80 mhz of bandwidth non overlapping
ofc its overlapping channel 11 its using channel 7 - 13
or you can split that up into 4 x 20mhz chunks
1 Above or 5 Below
and
13 Below or 9 Above
Would be interesting to see with a spectrum analyzer to see if that channel is actually used much...
12/13 would be great to use here in North America, as with this, one could actually do some interesting things that are in the small print and actually deploy a single 80MHz channel...
I already upset my neighbours with 2x40mhz channels they would love a single 80mhz one even more:)
