RT-N66U dropped connections
Vaporhead
Hope ya'll can give me some info. I've been losing my internet connections for the last 3 months. Cox communications have been out at least 4 times and they keep saying their lines are good.
I logged into the router and get the following in the log. It repeats this numerous times throughout the day. What does it mean? Also, I reverted from the most current firmware back down to 3.0.0.4.374_4561 thinkin that would help, nope. Any help would be appreciated.
Aug 8 14:45:17 WAN Connection: Ethernet link down.
Aug 8 14:45:17 stop_nat_rules: apply the redirect_rules!
Aug 8 14:45:32 WAN Connection: Ethernet link up.
Aug 8 14:45:32 rc_service: wanduck 295:notify_rc restart_wan_if 0
Aug 8 14:45:32 stop_wan(): perform DHCP release
Aug 8 14:45:32 kernel: Attempt to kill tasklet from interrupt
Aug 8 14:45:35 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Aug 8 14:45:35 rc_service: udhcpc 1581:notify_rc stop_upnp
Aug 8 14:45:35 miniupnpd[1569]: received signal 15, good-bye
Aug 8 14:45:35 rc_service: udhcpc 1581:notify_rc start_upnp
Aug 8 14:45:35 miniupnpd[1611]: HTTP listening on port 47338
Aug 8 14:45:35 miniupnpd[1611]: Listening for NAT-PMP traffic on port 5351
Aug 8 14:45:35 dhcp client: bound 192.168.100.10 via 192.168.100.1 during 30 seconds.
Aug 8 14:45:40 WAN Connection: WAN was restored.
Aug 8 14:46:10 WAN Connection: Ethernet link down.
Aug 8 14:46:10 stop_nat_rules: apply the redirect_rules!
Aug 8 14:46:19 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Aug 8 14:46:19 rc_service: udhcpc 1617:notify_rc stop_upnp
Aug 8 14:46:19 miniupnpd[1611]: received signal 15, good-bye
Aug 8 14:46:19 rc_service: udhcpc 1617:notify_rc start_upnp
Aug 8 14:46:19 miniupnpd[1647]: HTTP listening on port 40320
Aug 8 14:46:19 miniupnpd[1647]: Listening for NAT-PMP traffic on port 5351
Aug 8 14:46:19 dhcp client: bound 68.97.119.231 via 68.97.112.1 during 86400 seconds.
Aug 8 14:46:20 WAN Connection: Ethernet link up.
Aug 8 14:46:20 rc_service: wanduck 295:notify_rc restart_wan_if 0
Aug 8 14:46:20 stop_wan(): perform DHCP release
Aug 8 14:46:20 kernel: Attempt to kill tasklet from interrupt
Aug 8 14:46:20 miniupnpd[1647]: ioctl(s, SIOCGIFADDR, ...): Cannot assign requested address
Aug 8 14:46:22 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Aug 8 14:46:22 rc_service: udhcpc 1652:notify_rc stop_upnp
Aug 8 14:46:22 miniupnpd[1647]: received signal 15, good-bye
Aug 8 14:46:23 rc_service: udhcpc 1652:notify_rc start_upnp
Aug 8 14:46:23 miniupnpd[1682]: HTTP listening on port 48070
Aug 8 14:46:23 miniupnpd[1682]: Listening for NAT-PMP traffic on port 5351
Aug 8 14:46:23 dhcp client: bound 68.97.119.231 via 68.97.112.1 during 86400 seconds.
Aug 8 14:46:28 WAN Connection: WAN was restored.
Mark
This indicates that the Ethernet connection between the modem and the router is dropping. Most of the time it's the modem that's crashing and rebooting itself.
That's what I was thinking. They've replaced the modem twice already. I have all knew wiring in the house to this modem now too. Any chance some sort of interference could cause the cable modem to drop out?
Unlikely. Have you looked at the power supply and electrical plug where the modem is plugged? Could also be a defective port on the router.
Sent from my Nexus 4 using Tapatalk
I have good signals. Is it possible for the router to cause the modem to reset? I had to have this router repaired once before because the WAN port no longer worked.
Down
Channel 1: 6.9 dBmV 37.5 dB
Channel 2: 7.8 dBmV 37.8 dB
Channel 3: 7.1 dBmV 37.1 dB
Channel 4: 7.5 dBmV 37.7 dB
Channel 5: 6.5 dBmV 37.6 dB
Channel 6: 5.9 dBmV 37.4 dB
Channel 7: 5.9 dBmV 37.1 dB
Channel 8: 5.3 dBmV 36.8 dB
Upstream Channels
Power Level:
Channel 1: 47.0 dBmV
Channel 2: 46.7 dBmV
Channel 3: 46.7 dBmV
Channel 4: 46.7 dBmV
