RT-N66U Looses WAN
alon.albert
Hi
My setup is:
ISP Modem/Router is configured as a Modem only and is not serving any NAT.
My RT-N66U gets my external WAN IP over DHCP directly from my ISP.
Every once is a while, my RT-N66U will loose the WAN connection. The "Network Map" screen will say:
Internet status:
Disconnected
I discovered that I could restore the connection simply by unplugging the WAN cable from the router and re-plugging it.
In the system logs, I see this:
# irrelevant older log entries
Sep 8 15:43:12 dnsmasq-dhcp[811]: DHCPRELEASE(br0) 10.0.0.75 e8:ab:fa:0f:af:87
Sep 8 15:43:12 dnsmasq-dhcp[811]: DHCPDISCOVER(br0) 10.0.0.75 e8:ab:fa:0f:af:87
Sep 8 15:43:12 dnsmasq-dhcp[811]: DHCPOFFER(br0) 10.0.0.75 e8:ab:fa:0f:af:87
Sep 8 15:43:12 dnsmasq-dhcp[811]: DHCPREQUEST(br0) 10.0.0.75 e8:ab:fa:0f:af:87
Sep 8 15:43:12 dnsmasq-dhcp[811]: DHCPACK(br0) 10.0.0.75 e8:ab:fa:0f:af:87
Sep 8 15:43:14 WAN Connection: Ethernet link down.
Sep 8 15:43:14 stop_nat_rules: apply the redirect_rules!
Sep 8 15:45:50 WAN Connection: Ethernet link up.
The 15:45:50 corresponds to me re-plugging the cable.
Firmware Version:3.0.0.4.378_7410
Any ideas?
Have you tried replacing the modem-router Ethernet cable? Cat5e or Cat6.
Do any of the connectors appear 'loose' when plugged in?
I haven't tried a different cable yet. The existing cable is a factory made Cat5e (not self crimped) and all the connections are solid.
I suppose I could try different cable.
I've saw a suggestion on another thread that proposed putting a small switch between the router and the modem. I'll see if I can find a spare switch somewhere and give that a try.
Try DHCP query frequency to Normal
Set to normal. Will see what happens.
Even before I made the change, it's not happened for a few days. Seems pretty rare now.
seems to be a spate of similar probs, this one could be a loose connector on router or modem, see also
RT-N66U does not auto-reconnect to WAN
Is this a bug on Asus firmware? WAN disconnections
WAN IP renew issue
All seem to be wan type auto dhcp
There are at least 2 known issues, one is the failure to renew the dhcp lease correctly on time, the other is a fundamental problem with the ancient dhcp protocol - if your ISP breaks the connection while there is still a valid lease, there is no way for the ISP dhcp server to communicate the fact to the client, it is up to the client to notice and ask for new connection details.
