The router will reboot usually when my wife turns on her computer which is connected through wifi.
But other times, it will just reboot itself.
I am using a Motorola SB6121 modem and have Comcast.
The router reboots itself, the modem does not.
I've tried factory reset as well as using the latest Asus firmware and after that didn't help I tried the latest stable Merlin release.
The problem did not exist when I was using a $25 Rosewill router that unfortunately died and was then replaced with the RT-N66U.
This is the entire log file after the reboot happened.
Log file : http://pastebin.com/PHLtcT9Z
