RT-N66U USB HD unmounts itself when streaming movies
mirwin
Does anyone have any ideas how to stop a 2TB My Passport USB HD formatted with NTFS randomly unmounting itself from my RT-N66U while streaming movies (4Gb) to my HTPC running XMBC on Windows 8 via 20 meters of Cat 6? I annoyingly have to reboot the N66U a few times per movie.
Could this have anything to do with my 2TB My Passport USB HD always appearing in Windows Explorer as a Media device, but only sometimes appearing as a Network Device, under my other home Network PC’s?
I'm running 3.0.0.4.270 firmware.
Do you have any log entries in the System Log when the problem appears?
As 2TB (and more) drives mad some problems in the past: Why do you not check the latest Merlin firmware to see if it fixes your issue?
With kind regards
Joe :cool:
Thanks Joe, I installed Merlin's firmware and rebooted RT-N66U and all home PC's, but my USB HD still umnounts itself when streaming movies.
Logs below show what happened, any advice would be greatly appreciated.
FYI, SILVERDALEROUTA is the name of the offending USB HD
Mar 6 13:33:46 kernel: usb 1-1.2: reset high speed USB device using ehci_hcd and address 3
Mar 6 13:33:46 kernel: sd 0:0:0:0: [sda] Result: hostbyte=0x07 driverbyte=0x00
Mar 6 13:33:46 kernel: end_request: I/O error, dev sda, sector 350418352
Mar 6 13:40:26 kernel: hub 1-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
Mar 6 13:40:26 kernel: usb 1-1: USB disconnect, address 2
Mar 6 13:40:26 kernel: usb 1-1.2: USB disconnect, address 3
Mar 6 13:40:26 kernel: usb 1-1.4: USB disconnect, address 4
Mar 6 13:40:26 kernel: scsi 0:0:0:0: [sda] Result: hostbyte=0x01 driverbyte=0x00
Mar 6 13:40:26 kernel: end_request: I/O error, dev sda, sector 2792476920
Mar 6 13:40:26 kernel: end_request: I/O error, dev sda, sector 2792477160
Mar 6 13:40:26 kernel: usb 1-1: new high speed USB device using ehci_hcd and address 5
Mar 6 13:40:26 kernel: usb 1-1: configuration #1 chosen from 1 choice
Mar 6 13:40:26 kernel: hub 1-1:1.0: USB hub found
Mar 6 13:40:26 kernel: hub 1-1:1.0: 4 ports detected
Mar 6 13:40:26 kernel: scsi 0:0:0:0: rejecting I/O to dead device
Mar 6 13:40:26 notify_rc : stop_cloudsync
Mar 6 13:40:26 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 6
Mar 6 13:40:26 Cloudsync client: daemon is stoped
Mar 6 13:40:27 kernel: scsi 0:0:0:0: rejecting I/O to dead device
Mar 6 13:40:27 kernel: usb 1-1.2: device descriptor read/64, error -71
Mar 6 13:40:28 notify_rc : stop_nasapps
Mar 6 13:40:28 kernel: usb 1-1.2: device descriptor read/64, error -71
Mar 6 13:40:28 kernel: scsi 0:0:0:0: rejecting I/O to dead device
Mar 6 13:40:28 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 7
Mar 6 13:40:28 iTunes: daemon is stoped
Mar 6 13:40:28 mDNSProxyResponderPosix: mDNS_Deregister_internal: Record 7FBD18B4 not found in list 4 thehost.local. Addr 192.168.1.1
Mar 6 13:40:28 mDNSProxyResponderPosix: mDNS_Deregister_internal: Record 7FBD1BE0 not found in list 15 1.1.168.192.in-addr.arpa. PTR thehost.local.
Mar 6 13:40:29 kernel: usb 1-1.2: device descriptor read/64, error -71
Mar 6 13:40:29 FTP Server: daemon is stoped
Mar 6 13:40:29 Samba Server: smb daemon is stoped
Mar 6 13:40:29 mountd[988]: Caught signal 15, un-registering and exiting.
Mar 6 13:40:29 kernel: nfsd: last server has exited
Mar 6 13:40:29 kernel: nfsd: unexporting all filesystems
Mar 6 13:40:29 statd[968]: Caught signal 15, un-registering and exiting.
Mar 6 13:40:29 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 8
Mar 6 13:40:30 syslog: USB partition busy - will unmount ASAP from /tmp/mnt/My_Passport
Mar 6 13:40:30 notify_rc : restart_nasapps
Mar 6 13:40:30 FTP Server: daemon is stoped
Mar 6 13:40:30 Samba Server: smb daemon is stoped
Mar 6 13:40:30 rc_service: restart_nasapps is waitting restart_nasapps...
Mar 6 13:40:30 WEBDAV server: daemon is started
Mar 6 13:40:30 Samba Server: daemon is started
Mar 6 13:40:30 nmbd[1190]: [2013/03/06 13:40:30, 0] libsmb/namequery.c:getlmhostsent(782)
Mar 6 13:40:30 nmbd[1190]: getlmhostsent: group flag in lmhosts ignored (obsolete)
Mar 6 13:40:30 nmbd[1190]: [2013/03/06 13:40:30, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Mar 6 13:40:30 nmbd[1190]: Samba server SILVERDALEROUTA is now a domain master browser for workgroup HOMEGROUP on subnet UNICAST_SUBNET
Mar 6 13:40:30 kernel: usb 1-1.2: device not accepting address 8, error -71
Mar 6 13:40:30 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 9
Mar 6 13:40:31 notify_rc : restart_nasapps
Mar 6 13:40:31 rc_service: restart_nasapps is waitting restart_nasapps...
Mar 6 13:40:31 FTP Server: daemon is stoped
Mar 6 13:40:31 kernel: usb 1-1.2: device not accepting address 9, error -71
Mar 6 13:40:31 kernel: hub 1-1:1.0: unable to enumerate USB device on port 2
Mar 6 13:40:31 kernel: usb 1-1.4: new high speed USB device using ehci_hcd and address 10
Mar 6 13:40:31 kernel: usb 1-1.4: configuration #1 chosen from 1 choice
Mar 6 13:40:31 kernel: scsi2 : SCSI emulation for USB Mass Storage devices
Mar 6 13:40:32 Samba Server: smb daemon is stoped
Mar 6 13:40:32 WEBDAV server: daemon is started
Mar 6 13:40:32 Samba Server: daemon is started
Mar 6 13:40:32 nmbd[1218]: [2013/03/06 13:40:32, 0] libsmb/namequery.c:getlmhostsent(782)
Mar 6 13:40:32 nmbd[1218]: getlmhostsent: group flag in lmhosts ignored (obsolete)
Mar 6 13:40:32 nmbd[1218]: [2013/03/06 13:40:32, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Mar 6 13:40:32 nmbd[1218]: Samba server SILVERDALEROUTA is now a domain master browser for workgroup HOMEGROUP on subnet UNICAST_SUBNET
Mar 6 13:40:33 FTP Server: daemon is stoped
Mar 6 13:40:33 kernel: scsi 2:0:0:0: Direct-Access Multi Flash Reader 1.00 PQ: 0 ANSI: 0
Mar 6 13:40:33 kernel: sd 2:0:0:0: [sdb] Attached SCSI removable disk
Mar 6 13:40:33 kernel: sd 2:0:0:0: Attached scsi generic sg0 type 0
Mar 6 13:40:34 Samba Server: smb daemon is stoped
Mar 6 13:40:34 WEBDAV server: daemon is started
Mar 6 13:40:34 Samba Server: daemon is started
Mar 6 13:40:34 nmbd[1246]: [2013/03/06 13:40:34, 0] libsmb/namequery.c:getlmhostsent(782)
Mar 6 13:40:34 nmbd[1246]: getlmhostsent: group flag in lmhosts ignored (obsolete)
Mar 6 13:40:34 nmbd[1246]: [2013/03/06 13:40:34, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Mar 6 13:40:34 nmbd[1246]: Samba server SILVERDALEROUTA is now a domain master browser for workgroup HOMEGROUP on subnet UNICAST_SUBNET
Mar 6 13:40:42 nmbd[1246]: [2013/03/06 13:40:42, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Mar 6 13:40:42 nmbd[1246]: Samba server SILVERDALEROUTA is now a domain master browser for workgroup HOMEGROUP on subnet 192.168.1.1
Mar 6 13:40:57 nmbd[1246]: [2013/03/06 13:40:57, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(392)
Mar 6 13:40:57 nmbd[1246]: Samba name server SILVERDALEROUTA is now a local master browser for workgroup HOMEGROUP on subnet 192.168.1.1
Try a different USB cable, see if it helps.
USB disk support is a bit quirky with the router. Quite a few disks will have issues and randomly drop. Not much that can be done I'm afraid.
Thanks RMerlin for the advice, I changed the USB cable, but after 6 minutes of streaming a movie the USB HD Unmounted itself from my RT-N66U requiring me to reboot it.
Can anyone make any sense of the logs below (at 00:11:05 it looks like the USB Port was disabled by the RT-N66U), or am I better off changing my Router, USB HD or getting a NAS? None of which I want to do
Mar 7 00:05:29 kernel: usb 1-1.2: reset high speed USB device using ehci_hcd and address 3
Mar 7 00:11:05 kernel: hub 1-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
Mar 7 00:11:05 kernel: usb 1-1: USB disconnect, address 2
Mar 7 00:11:05 kernel: usb 1-1.2: USB disconnect, address 3
Mar 7 00:11:05 kernel: usb 1-1.4: USB disconnect, address 4
Mar 7 00:11:05 kernel: scsi 0:0:0:0: [sda] Result: hostbyte=0x01 driverbyte=0x00
Mar 7 00:11:05 kernel: end_request: I/O error, dev sda, sector 2754912264
Mar 7 00:11:05 kernel: scsi 0:0:0:0: rejecting I/O to dead device
Mar 7 00:11:05 kernel: end_request: I/O error, dev sda, sector 2754912904
Mar 7 00:11:05 notify_rc : stop_cloudsync
Mar 7 00:11:05 kernel: usb 1-1: new high speed USB device using ehci_hcd and address 5
Mar 7 00:11:05 kernel: usb 1-1: configuration #1 chosen from 1 choice
Mar 7 00:11:05 kernel: hub 1-1:1.0: USB hub found
Mar 7 00:11:05 kernel: hub 1-1:1.0: 4 ports detected
Mar 7 00:11:05 Cloudsync client: daemon is stoped
Mar 7 00:11:06 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 6
Mar 7 00:11:06 kernel: scsi 0:0:0:0: rejecting I/O to dead device
Mar 7 00:11:06 kernel: usb 1-1.2: device descriptor read/64, error -71
Mar 7 00:11:07 kernel: usb 1-1.2: device descriptor read/64, error -71
Mar 7 00:11:07 notify_rc : stop_nasapps
Mar 7 00:11:07 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 7
Mar 7 00:11:07 kernel: scsi 0:0:0:0: rejecting I/O to dead device
Mar 7 00:11:07 mDNSProxyResponderPosix: mDNS_Deregister_internal: Record 7FBC98B4 not found in list 4 thehost.local. Addr 192.168.1.1
Mar 7 00:11:07 mDNSProxyResponderPosix: mDNS_Deregister_internal: Record 7FBC9BE0 not found in list 15 1.1.168.192.in-addr.arpa. PTR thehost.local.
Mar 7 00:11:07 iTunes: daemon is stoped
Mar 7 00:11:08 kernel: usb 1-1.2: device descriptor read/64, error -71
Mar 7 00:11:08 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 8
Mar 7 00:11:08 FTP Server: daemon is stoped
Mar 7 00:11:08 Samba Server: smb daemon is stoped
Mar 7 00:11:08 mountd[935]: Caught signal 15, un-registering and exiting.
Mar 7 00:11:08 statd[914]: Caught signal 15, un-registering and exiting.
Mar 7 00:11:08 kernel: nfsd: last server has exited
Mar 7 00:11:08 kernel: nfsd: unexporting all filesystems
Mar 7 00:11:08 kernel: usb 1-1.2: device not accepting address 8, error -71
Mar 7 00:11:09 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 9
Mar 7 00:11:09 syslog: USB partition unmounted from /tmp/mnt/My_Passport
Mar 7 00:11:09 notify_rc : restart_nasapps
Mar 7 00:11:09 FTP Server: daemon is stoped
Mar 7 00:11:09 Samba Server: smb daemon is stoped
Mar 7 00:11:09 kernel: RPC: failed to contact local rpcbind server (errno 512).
Mar 7 00:11:09 rc_service: restart_nasapps is waitting restart_nasapps...
Mar 7 00:11:09 Samba Server: daemon is started
Mar 7 00:11:09 nmbd[1172]: [2013/03/07 00:11:09, 0] libsmb/namequery.c:getlmhostsent(782)
Mar 7 00:11:09 nmbd[1172]: getlmhostsent: group flag in lmhosts ignored (obsolete)
Mar 7 00:11:09 kernel: usb 1-1.2: device not accepting address 9, error -71
Mar 7 00:11:09 kernel: hub 1-1:1.0: unable to enumerate USB device on port 2
Mar 7 00:11:09 nmbd[1172]: [2013/03/07 00:11:09, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Mar 7 00:11:09 nmbd[1172]: Samba server SILVERDALEROUTA is now a domain master browser for workgroup HOMEGROUP on subnet UNICAST_SUBNET
Mar 7 00:11:09 statd[1175]: Version 1.1.6 Starting
Mar 7 00:11:09 kernel: usb 1-1.4: new high speed USB device using ehci_hcd and address 10
Mar 7 00:11:09 statd[1175]: statd running as root. chown /var/lib/nfs/sm to choose different user
Mar 7 00:11:09 kernel: NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
Mar 7 00:11:09 kernel: NFSD: starting 90-second grace period
Mar 7 00:11:09 kernel: usb 1-1.4: configuration #1 chosen from 1 choice
Mar 7 00:11:09 kernel: scsi2 : SCSI emulation for USB Mass Storage devices
Mar 7 00:11:10 FTP server: daemon is started
Mar 7 00:11:11 mt-daapd[1199]: Starting signal handler
Mar 7 00:11:11 mt-daapd[1199]: Loading playlists
Mar 7 00:11:11 mt-daapd[1199]: Initializing database
Mar 7 00:11:11 mt-daapd[1199]: Starting mp3 scan
Mar 7 00:11:11 mt-daapd[1199]: Starting web server from /rom/etc/web on port 3689
Mar 7 00:11:11 mt-daapd[1199]: Scanned 0 songs in 0 seconds
Mar 7 00:11:11 iTunes Server: daemon is started
Mar 7 00:11:11 notify_rc : restart_nasapps
Mar 7 00:11:11 rc_service: restart_nasapps is waitting restart_nasapps...
Mar 7 00:11:11 mDNSProxyResponderPosix: mDNS_Deregister_internal: Record 7FC8D8B4 not found in list 4 thehost.local. Addr 192.168.1.1
Mar 7 00:11:11 mDNSProxyResponderPosix: mDNS_Deregister_internal: Record 7FC8DBE0 not found in list 15 1.1.168.192.in-addr.arpa. PTR thehost.local.
Mar 7 00:11:11 iTunes: daemon is stoped
Mar 7 00:11:11 kernel: scsi 2:0:0:0: Direct-Access Multi Flash Reader 1.00 PQ: 0 ANSI: 0
Mar 7 00:11:11 kernel: sd 2:0:0:0: [sda] Attached SCSI removable disk
Mar 7 00:11:11 kernel: sd 2:0:0:0: Attached scsi generic sg0 type 0
Mar 7 00:11:12 FTP Server: daemon is stoped
Mar 7 00:11:12 Samba Server: smb daemon is stoped
Mar 7 00:11:12 mountd[1182]: Caught signal 15, un-registering and exiting.
Mar 7 00:11:12 kernel: nfsd: last server has exited
Mar 7 00:11:12 kernel: nfsd: unexporting all filesystems
Mar 7 00:11:12 statd[1175]: Caught signal 15, un-registering and exiting.
Mar 7 00:11:12 Samba Server: daemon is started
Mar 7 00:11:12 nmbd[1231]: [2013/03/07 00:11:12, 0] libsmb/namequery.c:getlmhostsent(782)
Mar 7 00:11:12 nmbd[1231]: getlmhostsent: group flag in lmhosts ignored (obsolete)
Mar 7 00:11:12 nmbd[1231]: [2013/03/07 00:11:12, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Mar 7 00:11:12 nmbd[1231]: Samba server SILVERDALEROUTA is now a domain master browser for workgroup HOMEGROUP on subnet UNICAST_SUBNET
Mar 7 00:11:12 statd[1235]: Version 1.1.6 Starting
Mar 7 00:11:12 statd[1235]: unable to register (statd, 1, udp).
Mar 7 00:11:17 kernel: NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
Mar 7 00:11:17 kernel: NFSD: starting 90-second grace period
Mar 7 00:11:18 FTP server: daemon is started
Mar 7 00:11:19 iTunes Server: daemon is started
Mar 7 00:11:19 mt-daapd[1262]: Starting signal handler
Mar 7 00:11:19 mt-daapd[1262]: Loading playlists
Mar 7 00:11:19 mt-daapd[1262]: Initializing database
Mar 7 00:11:19 mt-daapd[1262]: Starting mp3 scan
Mar 7 00:11:19 mt-daapd[1262]: Starting web server from /rom/etc/web on port 3689
Mar 7 00:11:19 mt-daapd[1262]: Scanned 0 songs in 0 seconds
Mar 7 00:11:19 mDNSProxyResponderPosix: mDNS_Deregister_internal: Record 7F8F98B4 not found in list 4 thehost.local. Addr 192.168.1.1
Mar 7 00:11:19 mDNSProxyResponderPosix: mDNS_Deregister_internal: Record 7F8F9BE0 not found in list 15 1.1.168.192.in-addr.arpa. PTR thehost.local.
Mar 7 00:11:19 iTunes: daemon is stoped
Mar 7 00:11:20 nmbd[1231]: [2013/03/07 00:11:20, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Mar 7 00:11:20 nmbd[1231]: Samba server SILVERDALEROUTA is now a domain master browser for workgroup HOMEGROUP on subnet 192.168.1.1
Mar 7 00:11:20 FTP Server: daemon is stoped
Mar 7 00:11:20 Samba Server: smb daemon is stoped
Mar 7 00:11:20 mountd[1254]: Caught signal 15, un-registering and exiting.
Mar 7 00:11:20 kernel: nfsd: last server has exited
Mar 7 00:11:20 kernel: nfsd: unexporting all filesystems
Mar 7 00:11:20 Samba Server: daemon is started
Mar 7 00:11:20 nmbd[1289]: [2013/03/07 00:11:20, 0] libsmb/namequery.c:getlmhostsent(782)
Mar 7 00:11:20 nmbd[1289]: getlmhostsent: group flag in lmhosts ignored (obsolete)
All the logs are telling us is what we already knew: the router has troubles talking with the USB disk, so it eventually gets disconnected.
Try formatting to ext3 after saving your data to another disk.
Sent from my HTC One S using Tapatalk 2
I was thinking in the same direction, but a more step by step approach.
a) Assuming that the disk is NTFS (Windows) formated:
- Run a check disk on the Windows PC to see if the disk content is OK
- Do some video playing/streaming on the Windows PC to see how the disk behaves
b) Only if you figure out a problem under the above checks
- Save your data to another disk and format the disk (under Windows and "not quick format") to stress it and to read all the sectors
- Put back the data a and retry the Router streaming
- If it still does not work, I would then give it a try for EXT3 formatting... :rolleyes:
With kind regards
Joe :cool:
Had the same issue, disconnecting, IO errors, especially after adding a 3TB disk to a 4bay enclosure.
Tried Ext4 and NTFS both same issues on AC56U.
Tested surface for bad clusters for 6 hours, none.
Then after a research found out there was a "feature" (self spindown) on the enclosure as:
http://forum.mediasonic.ca/viewtopic.php?f=22&t=1477
and had to change the firmware for it. (Not an upgrade)
Testing now, for the start seems OK, wanted to share for some having similar headaches.
