RT-N66U: Transmission using Entware with NTFS USB drive
suhail_ssr
Hi guys,
I am new to Merlin and i have recently installed Merlin Firmware 380.59 in my RT-N66U router.
I have installed Entware on a 2gb Flash disk with EXT2 partition without any error.
Followed the guidelines for Entware installation from here.
I have a 2TB USB External Harddisk (NTFS Partition) connected to the second USB port which has all my movie backups.
Now i want to install Tranmission and use it to download directly to my 2TB HDD in NTFS partition. Is it possible?
For this what kind of code should i put in that PUTTY app?
For your information: I haven't coded any script for auto start of entware so far. I have just installed entware and have done nothing beyond.
Need your help
Also suggest if Transmission is good or if anything else better than that available for torrent download.
Download Master works well on the N66 and you can tell it where to save the downloads. I save to a 1TB USB drive with the default settings. Well, sometimes I throttle the settings so the girls can surf!
Sent from my P01M using Tapatalk
