RT-N66U ver 378.55 - Chromecast
Tonye
Help Please.
Using my laptop Chromecasting works fine I can cast tabs, iPlayer, Netflix etc.
If I try to cast from any Android 5.1 devices the Chromecast device is recognised but when I start to cast I get "no chromecast compatible devices found". naturally I'm on the same LAN at 2.5Ghz.
By searching around it seems in addition to ensuring AP Isolation is off I need to change the the multicast settings under the LAN IPTV settings and the Enable VPN + DHCP Connection settings under WAN. I've tried various options and none have proved satisfactory.
Any suggestions for the correct settings to get Chromecast to work with Android devices would be much appreciated.
