RTRMON RTRMON v1.6.9 -May 3, 2024- Monitor your Router's Health (New: AMTM, Network Conn/Bandwidth/Diag + Port Scanner, GT-AXE/AX + Speedtest) [CLOSED]
well when you upgrade the graphics from ascii to 8-bit, I'll start getting more interested. how's your BASIC?
Hahah. Depends how good the graphics card in your router is! :D
Happy to announce a new RTRMON beta today... v1.06b1 is ready for a spin. @heysoundude - you got your wish. IP6 info is now readily available for your WAN and LAN. ;) Many thanks to @SomeWhereOverTheRainBow for his assist with this!
Download:
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/RTRMON/master/rtrmon-1.06b1.sh" -o "/jffs/scripts/rtrmon.sh" && chmod a+rx "/jffs/scripts/rtrmon.sh"
Screenshot:
Changelog:
v1.06b1
- ADDED:
Additional stats on the networking page, including the WAN and LAN IP6 addresses. Though my alignment OCD will have to live with the fact that IP6 addresses are variable length and won't fit nicely between brackets. Thanks to @SomeWhereOverTheRainBow for his assist in developing the code that pulls this info!
fair warning - its exhausting being me ;-)
Hahah... I'm definitely not planning on changing my handle to "Jack Yaz Jr" just yet. LOL
Man, I don't know how you do it! Jack used to be the guy that seemed to be in need of a break, now, you stayin in Viktory Lane, and a-smokin.....
Thanks for all the hard work to all you fellas.
We've got a BIGGIE for our RTRMON beta crowd today... We're leaping from v1.06b1 to v1.1b1! Putting on my @Jack Yaz Jr hat today, and introducing the capability of running Ookla Speedtests directly from RTRMON! This ain't no spdMerlin... no fancy graphics, graphs, history... just the bare minimum -- a spdMerlin-lite-lite if you will. LOL.
Download:
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/RTRMON/master/rtrmon-1.1b1.sh" -o "/jffs/scripts/rtrmon.sh" && chmod a+rx "/jffs/scripts/rtrmon.sh"
Screenshot:
Some changes to the configuration menu include enabling the Ookla Speedtest as well as a new entry to capture your Upload speeds for your WAN, since the vast majority of us out there are not symmetrical... would highly recommend making sure you stop by the configuration page and save your settings before running RTRMON! ;)
Changelog:
v1.1beta1
- MAJOR:
Added a major enhancement to RTRMON -- namely, the commandline Ookla Speedtest binary! Whoo! On the newly added Page 3 of the application, you can now initiate a manual speedtest! It will by default use your primary WAN connection and pick the closest server to you to run its test, and display these results on Page 3. These results are saved to a file, so next time you launch RTRMON, you will be able to see your last results. There are no fancy spdMerlin graphs or charts, but just good ol' plain data, and some progress indicators giving you a dashboard-like view of your actual vs max WAN up/down speeds. In the setup menu, you can now enable 'Ookla Speedtest', which will download and install the binaries. If you disable it, the setup menu will prompt you to uninstall these components for you.
- ADDED: Another variable has been added to capture your WAN upload speed. I personally don't have symmetrical up/download speeds, and using this will only give you a better indicator what's happening on your network as it measures and displays these results.
- ADDED: Additional stats on the networking page, including the WAN and LAN IP6 addresses. Though my alignment OCD will have to live with the fact that IP6 addresses are variable length and won't fit nicely between brackets. Thanks to @SomeWhereOverTheRainBow for his assist in developing the code that pulls this info! RTRMON v1.06b1 additions have been absorbed under this major release.
And as a major disclaimer... there comes a point where the CPU in your router can't handle the speed of your connection while running a speedtest, and as you see, mine tops out around 500Mbps on a 1GB connection. Your experience may vary depending on your connection speeds and the type of router/CPU you have. But this has been discussed ad nauseum in multiple other threads if you want to read up on this. The best way to measure your bandwidth is to plug a laptop directly into one of your LAN ports, and run a speed test directly through it, instead of making the router CPU try to handle this load.
Friday = Release day... ;) Enjoy new v1.1 coming out of beta, with some major changes, notably adding the Ookla Speedtest Binaries to the project!
v1.1 - (August 5, 2022)
- MAJOR:
Download:
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/RTRMON/master/rtrmon-1.1.sh" -o "/jffs/scripts/rtrmon.sh" && chmod a+rx "/jffs/scripts/rtrmon.sh"
Screenshot:
Houston, we have a problem ...
Also, 38 Mbps Download seems wrong ... I'm getting OVER 100 on the @Jack Yaz spdMerlin .
Does that mean his is "better" ? :p
Google Chrome192.168.1.254spdMerlin - Google ChromeScreen Shot 6 Aug 2022 at 10.27.18.jpg
LOL... those are some crazy results! First off... do you see a /jffs/addons/rtrmon.d/results.txt out there? If so, what's its contents?
Look at your crazy packetloss number... I'll look into this further, but it almost seems like your results are formatted differently, and am not grabbing the right content for its variables! :(
It would also be interesting for you to run "/jffs/addons/rtrmon.d/speedtest", and send those results too please? :)
First thing I went looking for, contents:-
SpdDate="Sat Aug  6 10:35:33 AEST 2022"
SpdServer="Exetel - Sydney" "13279"
SpdLatency=1.089
SpdJitter=0
SpdPacketLoss=13219878
SpdDownload=4737063
SpdUpload=54418736
Raw data looks good, I pay for a 100/40.
admin@AsusRouter:/jffs/scripts# /jffs/addons/rtrmon.d/speedtest
   Speedtest by Ookla
     Server: Optus - Sydney (id = 1267)
        ISP: Superloop
    Latency:     7.97 ms   (0.76 ms jitter)
   Download:   105.78 Mbps (data used: 89.7 MB )
     Upload:    37.62 Mbps (data used: 17.4 MB )
Packet Loss:     0.0%
Result URL: https://www.speedtest.net/result/c/67f0a154-b979-4288-bc4a-2c43ec792f88
Maybe Speedtest is upside down in this part of the world and @Jack Yaz has sneakily compensated ...
Same test from RTRMon GUI soon after, it even picked the same Optus server ...
SpdLatency=1.089
SpdJitter=0
SpdDownload=4737063
SpdUpload=54418736
   Speedtest by Ookla
        ISP: Superloop
Packet Loss:     0.0%
I think I see the problem... Let me work on this! Thanks for sharing this info!
Btw, looks like your packetloss is actually your download bytes/sec. Yeah, things are dropping into the wrong variables. Doh.
SpdLatency=1.089
SpdJitter=0
SpdDownload=4737063
SpdUpload=54418736
   Speedtest by Ookla
        ISP: Superloop
Packet Loss:     0.0%
Good news, @Stephen Harrington ... I think I caught the bugger. Could you please download this new version and see if that fixes your issue?
Download:
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/RTRMON/master/rtrmon-1.11.sh" -o "/jffs/scripts/rtrmon.sh" && chmod a+rx "/jffs/scripts/rtrmon.sh"
That's better, looking MUCH more plausible!
And with that, v1.11 is available! Minor bug fix release. ;) Many thanks to @Stephen Harrington for finding these bugs!
Download:
Changelog:
v1.11 - Aug 6 2022
- FIXED
: A parsing issue was generating some weird results due to the formatting of some the test servers, and subsequently dropping the wrong data into the wrong fields.
Bonus error handling bypass ... can anyone guess what causes this "crash" ?
Answer ... hitting the "N' key before:-
[Initiating Boot Sequence - Gathering Initial Stats...]
has completely finished its run ...
Probably needs to loop around into Gathering Initial Stats again, or ignore the key until "gather" has finished ...
Sorry @Viktor Jaep , in a mischievous mood tonight :p
Viktor Jaep RTRMON RTRMON v1.6.9 -May 3, 2024- Monitor your Router's Health (New: AMTM, Network Conn/Bandwidth/Diag + Port Scanner, GT-AXE/AX + Speedtest) Asuswrt-Merlin AddOns 15
Viktor Jaep TAILMON [RELEASE] TAILMON v1.0.12 -May 23, 2024- WireGuard-based Tailscale Installer, Configurator and Monitor (Now available in AMTM!) Asuswrt-Merlin AddOns 217
janico82 sbnMerlin 1.2.4 - Network Isolation Tool based on Guest Networks, May 11 2024 Asuswrt-Merlin AddOns 76
8 ASUS RT-AX58U (F/W Ver.:V3.0.0.4.384.8601) with Asuswrt-Merlin 3004.388.5 - Transmission: "Could not connect to the server. You may need to reload" Asuswrt-Merlin AddOns 2
thelonelycoder Diversion Diversion 5.1.3 - the Router Ad-Blocker, May 09, 2024 Asuswrt-Merlin AddOns 624
Viktor Jaep VPNMON VPNMON-R3 v1.3.5 -May 11, 2024- Monitor WAN/Dual-WAN/VPN Health & Reset Multiple OpenVPN Connections (Now available in AMTM!) Asuswrt-Merlin AddOns 209
thelonelycoder uiDivStats uiDivstats 4.0.0 - WebUI Stats for Diversion, April 21, 2024 Asuswrt-Merlin AddOns 28
thelonelycoder scMerlin scMerlin 2.5.3 - Service and script control menu for Asuswrt-Merlin, April 30, 2024 Asuswrt-Merlin AddOns 57
Viktor Jaep BACKUPMON BACKUPMON v1.7.2 -Apr 1, 2024- Backup/Restore your Router: JFFS + NVRAM + External USB Drive! CIFS/SMB/NFS! (Now available in AMTM!) Asuswrt-Merlin AddOns 237
Viktor Jaep BACKUPMON BACKUPMON v1.5.10 -Mar 1, 2024- Backup/Restore your Router: JFFS + NVRAM + External USB Drive! (**Thread closed due to age**) Asuswrt-Merlin AddOns 987
