RTRMON RTRMON v2.2.3 -Nov 16, 2025- Monitor your Router's Health (New: Wireguard, AMTM, Network Conn/Bandwidth/Diag + Port Scanner + Speedtest) - CLOSED
Will give it a try later today. Wife has me following her around in the malls to tote her purchases while she continues to shop.
VPN and ssh client solves that... 🤓
I hate making changes to router when logged in using a phone. I can and have ssh in remotely over VPN and just primarily use it to check on status and if necessary using scMerlin restart or stop something.
OK @CaptainSTX ... please give this a shot!
What's new?!
RTRMON v2.3.0b6 - (Release TBA)
- PATCH:
Added a better way to sort IP addresses, so they are accurately sorting from low to high. Thanks to @CaptainSTX for the nudge! :)
- PATCH: Specified max length values for the remainder of the wireless client table items, so that they will truncate should they go over their max length as to not skew the table layout.
Download link:
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/RTRMON/develop/rtrmon.sh" -o "/jffs/scripts/rtrmon.sh" && chmod 755 "/jffs/scripts/rtrmon.sh"
Significant Screenshots:
It's now sorting things right... :)
Works great! Thanks. I use certain predetermined IP ranges for different types of devices connecting makes it much easier to determine what is connected,
I understand your position completely, but I often do install/test things remotely on phone while waiting for wife...
Fortunately for me my AX88 Pro running the latest Merlin firmware is extremely stable. The router has been up 21 days without a reboot. VPMON keeps my VPN tunnels up and I use it's restart the tunnels in the early AM which helps to maintain the download speed through the tunnels running at 500 Mbps+ so accessing the router other than for curiosity isn't often necessary. Thanks to Merlin & Viktor Jaep for their work which makes this happen.
Looking forward to your feedback while we make our way through this beta!
Just dipping my toes in the water here on this addon - huge amount of work in typical @Viktor Jaep fashion!. Was looking for a better set of TX/RX and RSSI connected client stats than the Network Map in the WebGUI, which is invariably rather wonky.
The System Log, Wireless Log WebGUI Page only has the Main Router Stats AFAIK and not clients connected to AiMesh Nodes.
However I think, viewing pages 6 or 7 in this Addon, the clients connected to GNP SDNs are shown, but the TX/RX and RSSI are not, just MAC/Name and IP, is that correct? Or do I need to configure something else?
If not, would it be correct then, if I have Merlin FW on the Nodes, that I can see this detail on RTRMon if it’s installed on the Nodes, is that how it should work?
Just dipping my toes in the water here on this addon (huge amount fo work in typoical @Viktor Jaep fashion!. Was looking for a better set of TX/RX and RSSI connected client stats than the Network Map in the WebGUI, which is invariably rather wonky.
The System Log, Wireless Log WebGUI Page only has the Main Router Stats AFAIK and not clients connected to AiMEsh Nodes;.
If not, would it be correct then, if I have Merlin FW on the Nodes, that can see this detail on RTRMon installed on Nodes, is that how it should work?
That's correct. That info isn't available when clients are connected to VLANs... everything seems to be treated like a wired client in those cases, and wouldn't show any of the TX/RX/RSSI info because they're not visible using the wl command. That's not to say it will never be possible... but for now, this is all the info we can currently get to.
Ok, so just to double confirm, putting rtrmon on the nodes won’t give me that information either as it’s a VLAN issue? I’m not sure I’d do this anyway as then you’d need to ssh to the various nodes which means it’s not all in one place.
@jksmurf: This is what I see on AiMesh node (I installed it to test for you. FYI, there's a configuration setting to identify the device as AiMesh node — I don't recall all of the reasons for the flag). So, definitely no additional info...:
  Attached Wireless + Wired Clients
  Sort By:  (!)Name   |  (@)IP  |  (#)MAC
  Local 2.4GHz               [ Enabled                                                        ] IFace: eth10
  No Devices Connected
  Local 5.0GHz               [ Enabled                                                        ] IFace: eth7
  Local 5.0GHz (2)           [ Enabled                                                        ] IFace: eth8
  Local 6.0GHz               [ Enabled                                                        ] IFace: eth9
  Local Guest Wi-Fi          [ Enabled                                                        ] IFace: wl0.1
  Local Guest Wi-Fi          [ Enabled                                                        ] IFace: wl0.2
  Local Guest Wi-Fi          [ Enabled                                                        ] IFace: wl0.3
  Local Guest Wi-Fi          [ Enabled                                                        ] IFace: wl1.1
  Local Guest Wi-Fi          [ Enabled                                                        ] IFace: wl2.1
  Local Guest Wi-Fi          [ Enabled                                                        ] IFace: wl2.2
  Local Guest Wi-Fi          [ Enabled                                                        ] IFace: wl3.1
  Local Guest Wi-Fi          [ Enabled                                                        ] IFace: wl3.2
  Local Guest Wi-Fi          [ Enabled                                                        ] IFace: wl3.3
  Local Guest Wi-Fi          [ Enabled                                                        ] IFace: wl3.5
  Local VLAN/AiMesh VLAN     [ Enabled                                                        ] IFace: br52
  Local VLAN/AiMesh VLAN     [ Enabled                                                        ] IFace: br53
  Local VLAN/AiMesh VLAN     [ Enabled                                                        ] IFace: br54
  Local LAN/Non-VLAN AiMesh  [ Enabled                                                        ] IFace: br0
@jksmurf: I stand corrected. I forgot to install the latest beta. There IS additional data on the AiMesh node:
  RTRMON - v2.3.0b6                    (S)how/(H)ide Operations Menu                 Tue Dec 23, 2025 16:08:22 EST -0500
  Attached Wireless + Wired Clients                                         (Dedicated to @ExtremeFiretop and @visortgw)
  Sort By:  (!)Name   |  (@)IP  |  (#)MAC  |  [a=Enable/Disable Screen Run-off]
  Name              | IP              | MAC               | Uptime   | TX GB | RX GB | TX Mbps | RX Mbps | Sig | Band
  Local 2.4GHz Wi-Fi: 4089C985830B92F9D7D2A81848190072 - IFace: eth10
  No wireless clients connected
  Local 5.0GHz Wi-Fi: 4089C985830B92F9D7D2A81848190072 - IFace: eth7
  Local 5.0GHz-2 Wi-Fi: 4089C985830B92F9D7D2A81848190072 - IFace: eth8
  Local 6.0GHz Wi-Fi: 4089C985830B92F9D7D2A81848190072 - IFace: eth9
  Local 5.0GHz (Bridge: br0) - IFace: wl0.1
  Local 5.0GHz (Bridge: br0) - IFace: wl0.2
  Unknown           | Unknown         | D4:61:9D:0F:AC:A8 | 00h:15m  |  0.00 |  0.00 |   585.0 |    24.0 | -71 | 0x0:80
  Guest 5.0GHz Wi-Fi: TheS1RsGuests (Bridge: br54) - IFace: wl0.3
  Local 5.0GHz-2 (Bridge: br0) - IFace: wl1.1
  Local 6.0GHz (Bridge: br0) - IFace: wl2.1
  Local 6.0GHz (Bridge: br0) - IFace: wl2.2
  Local 2.4GHz (Bridge: br0) - IFace: wl3.1
  Local 2.4GHz (Bridge: br0) - IFace: wl3.2
  Guest 2.4GHz Wi-Fi: GetYourOwnDarnInternet (Bridge: br52) - IFace: wl3.3
  Unknown           | Unknown         | 24:62:AB:30:D2:76 | 00h:40m  |  0.00 |  0.00 |    65.0 |     6.0 | -54 | 0x0:20
  Unknown           | Unknown         | 34:3E:A4:07:42:05 | 00h:36m  |  0.07 |  0.15 |   156.0 |   173.2 | -37 | 0x0:20
  Unknown           | Unknown         | 3C:8A:1F:1A:DA:5C | 00h:39m  |  0.00 |  0.00 |    72.2 |     6.0 | -39 | 0x0:20
  Unknown           | Unknown         | 80:6A:10:11:44:ED | 00h:39m  |  0.00 |  0.00 |    72.2 |    11.0 | -55 | 0x0:20
  Local 2.4GHz (Bridge: br0) - IFace: wl3.5
  Local VLAN/AiMesh VLAN - IFace: br52
  No wired clients found
  Local VLAN/AiMesh VLAN - IFace: br53
  Local VLAN/AiMesh VLAN - IFace: br54
  Local LAN/Non-VLAN AiMesh - Subnet: 192.168.222.0/24 - IFace: br0
  Unknown           | 192.168.222.10  | 98:e7:f4:45:4a:49
  Unknown           | 192.168.222.16  | 7c:83:34:b4:e4:93
  Unknown           | 192.168.222.17  | 34:c8:d6:b1:01:10
  Unknown           | 192.168.222.1   | 10:7c:61:af:76:68
  Unknown           | 192.168.222.21  | 90:09:d0:77:70:35
  Unknown           | 192.168.222.220 | bc:87:fa:7b:32:f3
  Unknown           | 192.168.222.22  | 6c:1f:f7:15:bc:03
  Unknown           | 192.168.222.249 | 5c:a6:e6:b6:b4:1b
  Unknown           | 192.168.222.24  | 00:11:32:c0:d5:d0
  Unknown           | 192.168.222.251 | 00:11:32:c0:d5:cf
  Unknown           | 192.168.222.252 | 60:cf:84:18:ca:f8
  Unknown           | 192.168.222.253 | 04:42:1a:59:99:80
  Unknown           | 192.168.222.254 | 04:42:1a:58:7b:78
  Unknown           | 192.168.222.2   | 2c:cf:67:af:2c:94
  Unknown           | 192.168.222.5   | 90:09:d0:7a:4e:fe
  Unknown           | 192.168.222.96  | 7e:29:5d:7e:25:3a
Appreciate you doing that, it’s quite the Addon, with lots of screens, as I noted, just dipping my toes in the water. So thank you for doing that.
Ok, so if I understand this right, adding RTRMON to AiMesh Nodes (that suppprt Merlin FW) would represent pretty much the only way to get TX RX RSSI (Sig?) data of clients connected to nodes in the current Asus / Merlin / WebGui / Addon / script resource pool? Might be worth another look :-).
Correct!
I wonder if, having put RTRMON on the nodes to collect this magic data, young @Viktor Jaep could get the RTRMON instance on the main router to mine the nodes for info and present it all in one place, on the main router.
Another wonderful challenge to keep Viktor up nights …
As if @Viktor Jaep needs anything else to keep him up at night... 🤣
Wow, this kinda sounds like a smart mesh-networked client-server application that collects router data from disparate devices in order to present an accurate unified dashboard to give you a better view of your network. You might have better luck just buying a few enterprise Solarwinds licenses. Lol
I'm definitely not going to be able to sleep after all this! haha!
Wow, that's actually kind of interesting. So many unknowns! Yeah, I believe the reason for that switch had something to do with how it tries to reach out to get a public IP, location, city, how it does speed tests, etc... if I remember correctly. Maybe because it had a private IP instead of an actual public WAN IP. Vaguely remember. lol
"So many Unknowns!" could be because the nodes do not act as DHCP servers, and, therefore, they don't maintain hostname and IP address info (all controlled by the primary router).
Exactamundo. 👍 :cool:
This is what I ended up with, a show_main_rssi.sh script for the Main Router, not so much for sharing (although folks can use it if they want) more to demonstrate a format, a simple one-table format of Device Name, MAC, RSSI (dBm), Maybe Main or Node Name (latter not shown). It needs a file in the /jffs/scripts folder called mac_names.txt which has a simple MAC: Device_Name (no space after colon to Device) Table (I am sure that info is elsewhere anyway).
#!/bin/sh
echo "=== MAIN ROUTER CLIENTS ==="
for i in wl0.2 wl0.3; do
for MAC in $(wl -i $i assoclist 2>/dev/null | awk '{print $2}'); do
if [ -n "$MAC" ]; then
RSSI=$(wl -i $i rssi $MAC 2>/dev/null)
NAME=$(nvram get custom_clientlist | grep -o "[^<>]*>$MAC" | cut -d'>' -f1)
[ -z "$NAME" ] && NAME="Unknown"
echo "$NAME [$MAC]: $RSSI dBm"
fi
done
done | sort
echo ""
echo "To check node clients, SSH to each node:"
echo " ssh [email protected] # MB"
echo " ssh [email protected] # Annex"
echo " ssh [email protected] # Kitchen"
I use the same script on Asus Merlin Nodes (another good reason to use Merlin on Nodes...).
On stock, I use this, pasted straight into the CL after I SSH in.
I had 'help' getting these done and again, I am not expecting anything to end up in RTRMon, but if anyone was doing that, these simple tables are all I'd need :-). When I looked at RTRMon, this was what I was looking for, hence the original post above.
for i in wl0.1 wl0.2 wl0.3; do for MAC in $(wl -i $i assoclist 2>/dev/null | awk '{print $2}'); do RSSI=$(wl -i $i rssi $MAC 2>/dev/null); [ -n "$RSSI" ] && echo "$MAC: $RSSI dBm"; done; done | sort
This is what I ended up with as show_main_rssi.sh script for the Main Router, not so much for sharing (although folks can use if they want) more to demonstrate a format, a simple one-table format of Device Name, MAC, RSSI (dBm), Maybe Main or Node Name (latter not shown). It needs a file in the /jffs/scripts folder called mac_names.txt which has a simple MAC:Device_Name Table (I am sure that info is elsewhere anyway).
Nice work on coming up with a solution, @jksmurf! I may have already asked, but what happens if you run RTRMON on the nodes? Or are you looking for info other than the "unknown" values that you might get as @visortgw showed above?
âś–
