RTRMON RTRMON v2.2.3 -Nov 16, 2025- Monitor your Router's Health (New: Wireguard, AMTM, Network Conn/Bandwidth/Diag + Port Scanner + Speedtest) - CLOSED
Sure, I'll gladly help.
Sorry for the delay @fr0s7 ... please download this debug version:
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/RTRMON/develop/rtrmon-debug.sh" -o "/jffs/scripts/rtrmon.sh" && chmod 755 "/jffs/scripts/rtrmon.sh"
Then just run it like normal:
rtrmon -monitor
Wait until the script finishes running when it hits that error, then please copy all the output from your screen and dump it here below, or send me a file, or just PM it to me. I'd really appreciate it! :)
Done, attached is the output file.
Thank you! I think it has something to do with your CPU temps... could you please run this and see what you get back?
cat /sys/class/thermal/thermal_zone0/temp | cut -c -2
cat: can't open '/sys/class/thermal/thermal_zone0/temp': No such file or directory
Got to /sys/class/thermal directory but it's empty, I guess the temps are reported elsewhere?
Could you please give this a try?
cat /proc/dmu/temperature
cat: can't open '/proc/dmu/temperature': No such file or directory
There's no dmu dir in /proc
Is there anything under /sys/class/thermal/thermal_zone1?
cat: can't open '/sys/class/thermal/thermal_zone1': No such file or directory
cat /sys/power/bpcm/cpu_temp
cpu_temp: 64.758 C
Nailed it.
Hi @fr0s7 ... What is the actual output when you run this command? Does it just show:
Or is there other info when you run that command? I need specifics please. Please paste all the output from your screen after running that command if you don't mind?
I think what he showed is exactly the one-line output.
cpu_temp: 64.758 C
Nailed it.
OK @fr0s7 ... could you please give this patched version a shot, and see if this no longer produces errors, and gives you the correct temp readings?
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/RTRMON/develop/rtrmon.sh" -o "/jffs/scripts/rtrmon.sh" && chmod 755 "/jffs/scripts/rtrmon.sh"
Yes, this one works, checked different readings and all seems to match:
New BETA to test the waters and make sure is looking good... HUGE THANKS to both @ExtremeFiretop and @visortgw for their incredible team work on this! Both of these guys are amazing to work with!
What's new?
v2.2.4b2 - (Release date TBA)
- PATCH:
HUGE HUGE THANKS to both @ExtremeFiretop and @visortgw for their help getting the wired/wireless client page (#7) working again. Apparently something had broken between a firmware release that seemed to be causing some incorrect reporting on this page. Both these guys stepped in, and were able to collaboratively knock it out of the park, and get this page to report things accurately again. RTRMON wouldn't be as awesome as it is without these two incredible gentlemen! :) Thank you!
- PATCH: Thanks to a CPU temperature issue report from @fr0s7, it was found that the normal methods of finding CPU temp readings were no longer working on the RT-BE92U. @dave14305 came to the rescue, and was able to find the correct file for a temp reading. Thank you both!
- PATCH: Some oversight on my part... after my efforts to optimize my code, I inadvertently left out an optimization that affects vpn/wg connections that are using private IPs, and was causing a 1min delay when RTRMON started up. I got this added back in, and is launching successfully again. Thanks to @visortgw for the report!
- PATCH: Changed the date/time to include the offset alongside the timezone. This is to give more visibility for those who aren't assigned a standard timezone name, and in some cases would fall back to using "GMT". Thanks to @Tarek Yag for reporting this, and for @EmeraldDeer providing a deep dive into the date command options.
- PATCH: Various spacing tweaks to ensure alignment of required data elements. That's right. I blame the OCD.
- PATCH: Added the wireless channel spec to the table output list per @visortgw request. We may need to start widening the UI here soon! :)
Download link:
Significant Screenshots:
TZ offset now being shown. Also, please go check out the fixed wired/wireless network connections on page 7! :)
Added the band channel spec per @visortgw!
@Viktor Jaep: Doesn't need to be now, but I have a feature request for the wired/wireless client page (page 7)... Would it be possible to add the wireless band that each wireless client is connected to? I envision this being added to the end of each line next to the Sig value. It just came to mind that this was the one missing statistic.
Here's an example of everything you can see about a wireless client... do you mean the "chanspec 48/80 (0xe32a)" or the "link bandwidth = 80 MHZ" perhaps?
ViktorJp@GT-AX6000-3C88:/tmp/home/root# wl -i eth7 sta_info 04:27:28:3B:3C:22
[VER 8] STA 04:27:28:3B:3C:22:
         aid:11
         rateset [ 6 9 12 18 24 36 48 54 ]
         idle 9 seconds
         in network 35152 seconds
         state: AUTHENTICATED ASSOCIATED AUTHORIZED
         connection: SECURED
         auth: WPA2-PSK
         crypto: AES_CCM
         flags 0x11e13a: WME PS N_CAP VHT_CAP AMPDU AMSDU
         HT caps 0x1ef: LDPC 40MHz SGI20 SGI40 STBC-Tx STBC-Rx
         VHT caps 0x1b: LDPC SGI80 STBC-Tx STBC-Rx
         tx total pkts: 812763
         tx total bytes: 797076586
         tx ucast pkts: 798847
         tx ucast bytes: 794509579
         tx mcast/bcast pkts: 13916
         tx mcast/bcast bytes: 2567007
         tx failures: 166
         rx data pkts: 354487
         rx data bytes: 77557209
         rx data dur: 0
         rx ucast pkts: 353014
         rx ucast bytes: 77259826
         rx mcast/bcast pkts: 1473
         rx mcast/bcast bytes: 297383
         rate of last tx pkt: 866667 kbps - 468000 kbps
         rate of last rx pkt: 6000 kbps
         rx decrypt succeeds: 350681
         rx decrypt failures: 0
         tx data pkts retried: 50
         per antenna rssi of last rx data frame: -61 -57 -68 -67
         per antenna average rssi of rx data frames: -62 -57 -68 -67
         per antenna noise floor: -90 -91 -89 -91
         tx total pkts sent: 800644
         tx pkts retries: 51706
         tx pkts retry exhausted: 166
         tx FW total pkts sent: 0
         tx FW pkts retries: 0
         tx FW pkts retry exhausted: 0
         rx total pkts retried: 1650
MCS SET : [ 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ]
VHT SET : 0x1 1x1 2x1 3x1 4x1 5x1 6x1 7x1 8x1 9x1
        : 0x2 1x2 2x2 3x2 4x2 5x2 6x2 7x2 8x2 9x2
smoothed rssi: -57
tx nrate
vht mcs 9 Nss 2 Tx Exp 0 bw80 ldpc sgi auto
rx nrate
legacy rate 6 Mbps stf mode 0 auto
wnm
0x0:
VENDOR OUI VALUE[0] 00:0C:43
VENDOR OUI VALUE[1] 00:50:F2
RRM capability = 0x0
Frequency Bands Supported: 5G
