RTRMON RTRMON v2.4.0 -Apr 12, 2026- Monitor your Router's Health (New: Wireguard, AMTM, Network Conn/Bandwidth/Diag + Port Scanner + Speedtest)
Viktor Jaep
Part of the Furniture
RTRMON v2.4.0
Released April 12, 2026
Executive Summary: RTRMON is a shell script that provides near-realtime stats about your Asus-Merlin firmware router. Instead of having to find this information on various different screens or apps, this tool was built to bring all this info together in one stats dashboard. Having a 'system' dashboard showing current CPU, Memory, Disk and Network stats would compliment other dashboard-like scripts greatly (like VPNMON-R3), sitting side-by-side in their own SSH windows to give you everything you need to know that's happening on your router/network with a glance at your screen. Additional network diagnostics functionality was added, as well as insights into connections/speeds established to/from your router and the ability to run Ookla Speedtests against your WAN and (up to) 5 VPN connections!
RTRMON is free to use under the GNU General Public License version 3 (GPL 3.0).
This project is hosted on GitHub
Changelog [here]
Latest [
Release Notes]
What's new:
Syslog, New Memory Stats, GT-BE19000AI compatibility, Improved Wired/Wireless Connections Page, Major Wired/Wireless Client Page 7 Revamp, Optimizations, RT-BE92U Compatibility, Wireguard, Path, Column + general fixes, MLO Fixes, Fixes & Improvements, Wired/Wireless Client Page #7!, GT-AX11000_Pro Compatibility Fix, HUGE update to v2.x!, Large Drive Display Fix, Added EXT USB Storage & More, New Look & Feel, VPN Speedtest, Wi-Fi Scheduler Display, Updated Ookla Speedtest Binary + New Speedtest Stats!, Network Connections/Bandwidth Page, VPN Stats/Minimalist Progressbar/Custom Speedtest Server/+more!, Network Diagnotiscs + TCP/UDP Port Scanner, AMTM!, Further Router Compatibility, GT-AXE/AX Compatibility, WAN IFace Override, Fixed Progressbar %'s, Ookla Speed Test Functionality!
Requirements:
1.) Asus/Merlin firmware
-- apparently stock Asus is missing some of the features that RTRMON requires to display its stats.
Compatibility:
1.) The vast majority of Dual-Band Routers
  • Where wl0 = 2.4GHz, wl1 = 5GHz: RT-AC86U, RT-AX86U, RT-AC68U, GT-AX6000, etc. all are supported by default
2.) Tri-Band Routers /w WiFi6
  • Where wl0 = 2.4GHz, wl1 = 5GHz(1), wl2 = 5GHz(2): GT-AX11000_Pro, GT-AX11000, ZenWiFi_Pro_XT12, ZenWIFI_AX
3.) Tri-Band Routers /w WiFi6E
  • Where wl0 = 2.4GHz, wl1 = 5GHz, wl2 = 6GHz: GT-AXE11000, RT-BE96U, RT-BE92U, GT-BE19000AI
4.) Quad-Band Routers w/ WiFi6E
  • Where wl0 = 5GHz(1), wl1 = 5GHz(2), wl2 = 6GHz, wl3 = 2.4GHz: GT-AXE16000, GT-BE98
  • Where wl0 = 5GHz, wl1 = 6GHz(1), wl2 = 6GHz(2), wl3 = 2.4GHz: GT-BE98_Pro
**I will add more devices to the Tri/Quad-Band compatibility list as I research how each one has their wireless interfaces configured. If you see something not working right, please leave a note in this forum, or PM me!
Screenshots:
Page 1: Main CPU, Memory & Disk
Page 2: WAN, LAN and VPN Connections
Page 3: Wi-Fi Bands
Page 4: Speedtest
Page 5: Basic Diagnostics & NMAP Port Scans
Page 6: Current connections/bandwidth for your WAN, LAN and VPN Connections:
Page 7: Attached Wireless and Wired Clients:
Newly added Page 8 - Syslog!
I would recommend running this script in its own SSH window from a PC that's connected directly to the Asus router, or from a utility like 'Screen', as it loops and checks the various stats every 10 seconds. Instructions:
  1. Download and install directly from AMTM, or using your favorite SSH tools, copy & paste this command:
    curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/RTRMON/main/rtrmon.sh" -o "/jffs/scripts/rtrmon.sh" && chmod 755 "/jffs/scripts/rtrmon.sh"
  2. Configure it using this command:
    sh /jffs/scripts/rtrmon.sh -setup
  3. Run it standalone in an SSH window with this command:
    sh /jffs/scripts/rtrmon.sh -monitor
  4. Or, using the screen utility, which has now been built-in:
    sh /jffs/scripts/rtrmon.sh -screen
  5. To make it even easier, simply execute the script name with the commandline switch, like so:
  6. Code:
    rtrmon -screen
    -or-
    rtrmon -monitor
    -or-
    rtrmon -setup
    etc...
Please note: in order to use the shortcut method as explained in step 5, you will need to log out of your SSH session completely/close it, then re-open it and log back in. Then you can use the command "rtrmon" from any subfolder location.
You can enter the setup screen with the command 'sh rtrmon.sh -setup' or by hitting the "M" key in the main UI:
Hitting the "1" option, there are currently 14 items you can configure (you can also access this screen by using 'rtrmon -config'):
The really important ones probably are your max speeds... as those will differ from router to router, home to home, location to location. Each menu item has detailed explanations on what each one means. If you have any further questions, please feel free to post in the thread below.
I'm definitely looking for your feedback... what works, what doesn't... what else would you like to see. But all-in-all, as good ideas come up for things to possibly add, very much a WIP (work-in-progress).
To kick this new thread off right, how about we just get the latest version of RTRMON v2.3.0 out the door! ;) Sorry for the sheer amount of release notes... There's a LOT of new fixes and behind-the-scenes enhancements, with the biggie being page 7: a newly revamped wired/wireless connections page!
What's new!?
v2.3.0 - (January 10, 2026)
- PATCH:
Wanted to give HUGE HUGE THANKS to both @ExtremeFiretop and @visortgw for their help getting the wired/wireless client page (#7) working again. Apparently something had broken between a firmware release that seemed to be causing some incorrect reporting on this page. Both these guys stepped in, and were able to collaboratively knock it out of the park, and get this page to report things accurately again. RTRMON wouldn't be as awesome as it is without these two incredible gentlemen! :) Thank you!
- MINOR: The fixes above led to a complete rework of the wired/wireless client page in order to streamline and make it easier to understand and troubleshoot. As @ExtremeFiretop explained, the methodology he was going down was causing patch after bandaid after patch as requirements and firmware continued to change things over time. This gave us a chance to reset using all the knowledge that @ExtremeFiretop had amassed thus far into a new working version. Again, HUGE THANKS to both @ExtremeFiretop for his incredible knowledge and dedication, and for @visortgw for his relentless testing and feedback using the massively large and complex network he has at his disposal for running RTRMON through the ringer! :) This page 7 has now been officially "Dedicated to @ExtremeFiretop and @visortgw" for their hard work on this!
- PATCH: The new wired/wireless page 7 has column headers moved to the top of the page, instead of at the top of each interface to reduce page draws and size.
- PATCH: The new wired/wireless page 7 now has a page run-off limiter set to 24 rows, and will indicate if more rows are available. Pressing the (A) key will show ALL rows through each refresh cycle, until you press (A) again to limit run-off. This prevents clutter for those who are running large networks and would rather not deal with the constant run-off screen refreshes.
- PATCH: Thanks to a CPU temperature issue report from @fr0s7, it was found that the normal methods of finding CPU temp readings were no longer working on the RT-BE92U. @dave14305 came to the rescue, and was able to find the correct file for a temp reading. Thank you both!
- PATCH: Some oversight on my part... after my efforts to optimize my code, I inadvertently left out an optimization that affects vpn/wg connections that are using private IPs, and was causing a 1min delay when RTRMON started up. I got this added back in, and is launching successfully again. Thanks to @visortgw for the report!
- PATCH: Changed the date/time to include the offset alongside the timezone. This is to give more visibility for those who aren't assigned a standard timezone name, and in some cases would fall back to using "GMT". Thanks to @Tarek Yag for reporting this, and for @EmeraldDeer providing a deep dive into the date command options.
- PATCH: Various spacing tweaks to ensure alignment of required data elements. That's right. I blame the OCD.
- PATCH: Added the wireless channel spec to the table output list per @visortgw request. We may need to start widening the UI here soon! :)
- PATCH: All screens have now been widened by 10 characters to accommodate for the slightly wider table sizes under the wired/wireless client page 7.
- PATCH: Column 1 under the wired/wireless client table is limited to 16 characters, and will trim any client names > 16 characters.
- PATCH: NMAP results on the Network Diagnotics Page 6 are now indented by 3 characters to show better placement under the various interfaces it is reporting on.
- PATCH: Per suggestions from @visortgw, changed defaults to disable screen run-off limiter, and can be enabled anytime using (A). Also, extended column 1 that shows the device name from 16 chars to 17 chars. Thank you!
- PATCH: Added a better way to sort IP addresses, so they are accurately sorting from low to high. Thanks to @CaptainSTX for the nudge! :)
- PATCH: Specified max length values for the remainder of the wireless client table items, so that they will truncate should they go over their max length as to not skew the table layout.
- PATCH: Fixed the Wi-Fi stats page, as it was using an older method of collecting interface stats. With the newer routers implementing per-SSID/VLAN accounting at the driver level, the parent interface (ex: wl0) no longer accumulates statistics directly. This new method of capturing this info should be backwards compatible with other routers and older firmware. TBD! ;)
- PATCH: Changed some of the wording within the script from "iMesh" to "AiMesh" as this is what it is formally known as today. Also, fixed the commandline instructions to indicate that pages 1-7 are able to be called from a "rtrmon -monitor 3" optional type of command to jump right to that particular page. Thanks @jksmurf!
Download link (or update directly within RTRMON or AMTM):
Significant screenshots:
Added the "band" column,
Fixed spacing, and revamped the method at which this info is being collected.
IP's are being actually now able to be sorted correctly from low to high:
Wi-Fi RX/TX stats fixed:
Definitely more to work on... have more plans on development of the Wired/Wireless Clients Page (7) ahead! Enjoy!
Fantastic thank you!
Just wanted to report that on an iPad at least:
rtrmon -monitor 7 works beautifully to get me to screen only.
However rtrmon -screen 7 or rtrmon -screen 7 -now does not, it goes directly to the first screen only. I believe @scootertramp was seeing the same thing at one stage.
Son of a gun... looks like I accidentally backed out this fix somehow... must have hit CTRL-Z one to many times. LOL
Please update & download the same version over what you currently have. That will fix it. Just tried it again just to be sure. :)
can you add support for RT-BE86U, I can do testing if needed.
Happy to help, but please help me understand what RTRMON is currently doing (or not doing)?
Can you send some screenshots of the problem areas you're seeing. AFAIK, it uses a standard 2.4GHz/5GHz setup?
Thank you in advance!
It works, my bad..I forgot to show operations menu. also, I wasn't able to get 6ghz to recognize.
any chance this gets added to web interface?
Glad to hear you got it working. But I'm sorry to say, you'll never see 6GHz on this router. Though it's a "WiFi 6"/"WiFi 7" router, it only uses 2.4GHz and 5GHz radios.
Also, if you're looking to get stats on an iMesh node, make sure that when you install it on your node, that you mark it as an iMesh node/repeater/bridge. :)
Throwing a new RTRMON beta out your way to make sure everything is looking good on the Wired/Wireless Networks (Page #7)!
What's new?!
v2.3.1b1 - (March 1, 2026)
- PATCH:
Fixed a few outstanding items on the wired/wireless client page (#7) that were still irking me. First, adding an option (b) that will now show/hide networks with no connected clients. This will drastically reduce clutter for many of you. Default settings will hide networks with no connected clients. Second, instead of showing a 32-character alphanumeric Enhanced Open or OWE Transition hash as an SSID, it now shows the friendly SSID name along with [Enhanced], or just [Enhanced Security] when an SSID is not available. Many times these networks would also have 0 clients connected to them, however @visortgw has shown that other routers (or clients) do connect to them as bridges or backhaul. All in all, the interface now looks less cluttered and less confusing. Hope this is helpful!
- PATCH: Added some more logic to ensure that the timer is being utilized correctly when rendering the bar charts across the screen. More accuracy now when moving between screens and implemented separate counters being used to render CPU/Memory vs. wired/wireless transfer stats.
Download link:
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/RTRMON/develop/rtrmon.sh" -o "/jffs/scripts/rtrmon.sh" && chmod 755 "/jffs/scripts/rtrmon.sh"
Significant Screenshots:
Using the "b" hotkey, you can now show/hide networks that have no clients connected to them
Those particular interfaces that showed a 32-char OWE hash will now show with a friendly SSID + [Enhanced] tag, or when not available, just shows [Enhanced Security]
What's new?!
- PATCH:
Download link:
Excellent addition, @Viktor Jaep! You are helping my OCD (as well as your own)...
Bogo today, getting RTRMON v2.3.1 out in your hands as well... huge improvement in accuracy when moving between pages with the introduction of separate counters, and an improvement of displaying the wired/wireless clients on page #7! Enjoy!
What's new!?
v2.3.1 - (March 8, 2026)
- PATCH:
- PATCH: Added some more logic to ensure that the timer is being utilized correctly when rendering the bar charts across the screen. Huge improvement in accuracy now when moving between screens and implemented separate counters being used to render CPU/Memory vs. wired/wireless transfer stats.
Wired/Wireless page #7 is now much less cluttered and now optionally gives you only networks that are being used!
I leave it as optional since a lot of times, it gets installed when other tools are installed. It's just one of those old tools that nobody ever uses anymore... so I don't want to force it on people. :)
Hello Viktor,
First, thanks for the great tool, I'm very late on the bandwagon and only installed RTRMON (latest 2.3.1 version) last week on my RT-AX88U to check on my open WAN ports (will post some snmpd info in another thread).
Just wanted to let you know that in my case, dig was not installed, and being a bit new to power-using my router, had to google a bit to find why there was the failure. Would it be good at install time, when you check for dependencies, to check for dig availability and provide the commands (or prospose to execute them) to install dig?
Thanks and have a good day!
(p.s.: After reading the 25 pages of the original thread, and seeing that there were 2 other 25-pages thread, I gave up on trying to read everything to catch up, so apologies if this has been discussed more since the post I quoted above)
Hello Viktor,
Thanks for the feedback on this, @info_dan! I'll see if I can at least throw a warning up that dig isn't going to work unless it gets installed, or prompt to install it if it doesn't find it. I'm not a huge fan of forcing the installation of additional tools on someone's router because a particular test needs it, and would rather give the user that option. Not having dig doesn't hurt anything, but just another tool that helps determine if everything is working right.
Just reach out if you have any questions... no need to read these years upon years of posts! :)
I do like this script but it would be even better if it supported Dual Wan, especially for the Speed Test and the page where it shows your WAN and VPN download\upload traffic speeds.
Currently it can pick either WAN Interface.
Very true... I personally don't use Dual WAN, and would be difficult to test to see if I can get these functions working right. I love the idea though, and will definitely add this to my list!
I have Dual WAN and coding knowledge, the thing I'm lacking right now is availability. Would it be good to create a GitHub issue to track this request? PhunkyPhil could create it, provide details on their setup and the behavior observed. In a few weeks (months?) I could take a look at it, if it has not been adressed by then.
I appreciate the offer, @info_dan. I should be able to knock it out within a few weeks is my guess. Definitely will need some help testing from those with dual WAN. ;)
RTRMON 2.4.0Beta3 coming your way with multiple new features and functionality! Would appreciate feedback from @PhunkyPhil, @info_dan or anyone else running dual-WAN to ensure the speedtest functionality on page 4 works as advertised! Thank you! :)
What's New?!
v2.4.0b3 - (TBA)
- MINOR:
Implemented page #8 - Syslog! RTRMON will now display a scrollable syslog, showing the latest events by default in a condensed view. You have the option to scroll up, down, look at the raw, expanded view or refresh the log to see the latest items on the log.
- PATCH: Fixed the Diagnostics page to indicate "skipped" if the dig command is not found. It will show install instructions along the side for those who want to install the dig tool so that it will complete the network diagnostics test in its entirety. Huge thanks to @info_dan for this suggestion!
- PATCH: RTRMON as of this version is now compatible with the new GT-BE19000AI thanks to @jzchen for his help pulling the wireless interface assignments from his unit! :)
- PATCH: Based on feedback from @PhunkyPhil, the Speedtest functionality (page 4) is now able to test your bandwidth using either the WAN0 or WAN1 interfaces. Thank you!
- PATCH: Added the verbiage "**NOTE: NMAP WAN Results may be misleading. Please test thoroughly with External Port Scan (ie. grc.com)" to the bottom of the Network Diagnostics page, to indicate that the nmap results you get testing against the WAN interface locally are not what is representative when doing this same test from an external device (outside the WAN).
Download link:
New Syslog functionality on Page 8!
Ability to select either WAN0 or WAN1 for speedtests:
