Software Updates - RV340 Dual WAN Gigabit VPN Router | ||||||||||||||
A new firmware installation verification mechanism is optimized to reject invalid
images. DO NOT downgrade the Firmware from1.0.03.27 to 1.0.03.24 or other
earlier versions.
If you really want to downgrade, select inactive version (1.0.03.24 or earlier) then
reboot the router.
I see this as a check box in the UI in Wan > WAN Settings. It's unchecked. I'm not at all clear what it does. The release notes show very (see above quote) and all the "i" mouse over shows is "Bypass DHCP Server-ID check against DHCP NAK". Cisco's bugsearch for CSCvz96100 says "You are not entitled to access bug: CSCvz96100". Conclusion: It's a mystery, but by default the field is not enabled and I presume that is what Cisco intends as default (safest) behavior.What’s New
Added DHCP NAK option to bypass the Server-ID check for specific scenarios.
Thread starter | Title | Forum | Replies | Date |
S | Pro-sumer WiFi 6/6E routers with support for VLAN, VPN, SSH, and some custom firmware | Routers | 55 | |
Tomato64 - x86-64 port of the Tomato Firmware Distribution | Routers | 4 |
Welcome To SNBForums
