RV042G Giving Poor Performance
work_permit
SMB and its companion forums are great sites. I've been lurking in these forums and they've helped me alot. Now I'm stuck, and hope some of you can help.
My RV042G is giving me roughly 130 Mbps maximum throughput WAN->LAN (download) on a WAN link rated for 300 Mbps. I've used both speedtest and verizons downlink test site, and get similar results. Using Verizons Actiontec router, I am able to achieve the rated link speed from either site.
I've tried disabling SPI, and of course testing with only one computer connected directly to the router. There's a thread over at cisco's support community where another user is achieving similarly bad real world results. SMB was able to achieve >600 Mbps in their lab test.
Are these results that should be expected? Am I doing something stupid? Do I have a bad unit? Or is there that much discrepency between SMB lab tests and real world results?
Our tests use IxChariot on a private LAN, so are ideal best cases with very few variables to deal with.
Perhaps WAN MTU is different for the two routers?
Speed Tests
Hello there,
I setup a RV042G and two computers running jperf. Other than forwarding port 5001 to the internal computer and setting a static IP address on the WAN port, the setup was default.
Jperf reported a around 130 Mbps total throughput. However, when I increased the Windows size in Jperf to 64 KBps, total throughput increased to an average of 400-425 Mbps.
I am investigating this further and will be contacting you shortly.
-davidagu (at) cisco (dot) com
I've sent you what I have mine configured under Windows 7 H-64BT the last line is what you need. 7 32-bit nor 64-bit will needs a patch for that to be enabled. Otherwise it won't be. But it's available by default under Windows 8 set to 3000 which default. Some set it to 600 for BT connects but I don't recommend doing that.
